After replacing gasket on filter vacuumed the pool and then the pool was crystal clear but an hour later when the filter was running the pool was dirt back in pool
Usually sand blowing back into the pool is either cracked laterals, a cracked hub assembly (what the laterals screw into) or a bad spider gasket is wrong with pool filters. If you are certain that the laterals and hub are not cracked then I would try replacing the spider gasket.
did you replace the spider gasket in the multiport valve?
Which gasket?
