SOURCE: filter is shooting sand back into the water when
SOUNDS LIKE YOU ARE IN RECIRCULATE MODE TAKE HANDLE AND MOVE IT TO ALL THE POSITION TO TEST BACK WASH CYCLE ETC SAND SOULD BE FINE CHECK TO SEE IF YOU HAVE ENOUGH
SOURCE: when vaccum dirt, comes back in thru jets. \have a hayward filter
Do you back-wash your filter regularly?
Sound like dirt build up.
SOURCE: Dirt comes back thriugh the return when I vacuum
if your pool is clean its not sand when we vac customers pools we put vac in pool and put vac hose over pool take a wet vac put on end of hose outside pool keep it on only long enough to get water flowing save your filter and water if you want to vac through skimmer make sure you are in filter mode good luck
SOURCE: My sand filter has great flow for awhile, and then
one of the internal pipes broke or rotted away put in bypass mode and unbolt top slide out unit head repair or replace damage pipe
SOURCE: Not filtering correctly
The alge will always work through the filter and eventually cause problems in the filter. What you need to do is kill all the alge so when it's dead and just dirt the filter will collect it A small amount of DE powder in the skimmer will help at this point but be sure the alge is killed off first. You can use a lot ok liquid chloriene to start the process. Depending on how bad it is and how big a pool you have. I will usually start with about six to ten gallons and repete after twelve hours if nessary.
