Soyo DYLT032C 32 in. LCD Television Logo
Anonymous Posted on Feb 01, 2010
Just trying to hook up a DVD player to the TV. Soyo remote is broken so i am having difficulties. I hooked up the DVD to TV connectiing the red, white, and yellow cables to audio on TV to the DVD. I manually pressed source and it's on S-Video. What channel does the TV and DVD belong. TV was on 3 and it said no sync detected. What should I do.
Marvin
Level 3:
Top Expert:
  • Soyo Master 85,242 Answers
  • Posted on Feb 01, 2010
Marvin
Soyo Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060613
Points
266281
What is the output set for on the DVD player? S video is not what u want, do u have a auxiliary input? if u want to use S video get a cable from Radio Shack, the channel is used for older devices, the channels for this where 3 and 4 but this will not work, if u have a button marked Video in press it until the player shows on the screen.
2helpful
I'm trying to hook my DVD player to my tv its a vizio flat screen but I keep getting a Aucum Signal... What do I do
hook your dvd player into video 0ne two or three, there indication is red white and yellow. red for left sound white for right sound and yellow for video. then turn your tv to video output to what ever you attatched your rca cable to either vid 1 2 or 3. the remote should have an input selection, good luck this is easy and if you hook the cables up to the red white and yellow connections either on the side front or back of the tv it will detect it normaly, if not choose it from the remotes selection tab, called input selection. hope this helps.
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
I am trying to hook up a dvd player to my Symphonic TV. (ST420FF) When I hook the red, white and yellow cords to the back of the dvd player, I can't find it on the tv. I don't see a line in or line out...
try to look first the video in commonly the color is yellow, white, red the yellow one is the video and the white,red is the audio if you connect it press the video on your remote.
1helpful
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
I have a Soyo Model# DYLT032C. My remote has been broken since I bought the TV. However, I'm just trying to make the DVD Player work. No cable TV, just want the DVD working. Since the TV Remote is...
As you look at the tv from the front, you have the tv function keys on the lower right hand side, press the key described as source once at a time till you get to the input you are using for the dvd player, ex: if dvd is connected to input 2, press the source key repeatedly untill you get to input2, this should give you control over the external inputs you are trying to use. As for the remote control, there should be a universal remote control you can program to use with your soyo tv.
I have a dvd player that I am trying to hook up to a sharp tv model number 25L-M100B. This tv don't have the necessary ports inthe back to plug dvd or anything up to it. It does have 2 in the front of
Hook the dvd player up to the front inputs usually a yellow and a red or possibly a yellow red and white depending if the TV is stereo or not.
Then on your remote, it the INPUT button and take it to "VIDEO 1" while your dvd player is on and you should get a picture.
Make sure not to mix the cable colors.
Yellow is video
White Audio
Red Audio
A lot of times there is only either white or red and not both. This is just Mono sound, it works, just not "stereo" sound.
2answers
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Dvd/tv hook up
plug in dvd player direct to tv yello red white for sound into a input ok vidieo one ect then change input on tv to that input ch2 hit ch down to go into inputs
2helpful
3answers
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Top Soyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
