20 Most Recent Panasonic DMR-E30 DVD Recorder Questions & Answers
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Panasonic... • Answered on Dec 09, 2017
Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
and here are some other HACKS for your players
like Macrovision bypass ISCSI BAYPASS ETC
http://www.videohelp.com/dvdhacks/panasonic-dmr-e30/1585
Panasonic... • Answered on Apr 30, 2013
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Panasonic... • Answered on Oct 07, 2011
Hello michaelk960,
First you need to know that the machines problem is from the control panel of the DVD. Because it just simply cannot go off without the power off butoon is being pressed from either the remote ir the control panel.
If you try to control the DVD using the remote also and it simply would not respond and still go off. Then the problem is confirmed as two buttons cannot work on the DVD at the same time. The power button is pressing itself on the control panel that is why it goes off after about 10secs. If the player is to write BYE on the display panel, it means the power off button have been pressed, if not, by you, then it is by an error on the control panels board, which is making no other button function.
The solution is for you to have the control board replaced. To replace the control panel board. Simply unplug the player, then you unscrew the screws that are around the player, then you slide open the back cover of the player, then you unscrew the front control panel from the inside of the player, then you disconnect the flexi ribbon that connects the control panels board to the main board. Then you replace the board with another board and reverse the process to reassemble the player back together.
That way, the control off opening, closing and other function keys on the player and remote will be able to work once again.
Would be glad to know if the information helped. All the best michaelk960. Elect_Comp
Panasonic... • Answered on Sep 05, 2011
Hello
If you see the display lie that "Non reocrdable disc" These are the reasons.
[1] The unit cannot record on the disc you inserted. Insert a DVD-RAM or unfinalised
DVD-R, DVD-RW (DVD-Video format), +R or +RW.
[2] You inserted an unformatted DVD-RAM, DVD-RW, +R, +R DL or +RW
[3] You cannot directly record to a DVD-R DL and +R DL disc on this unit. Record to the
HDD and then copy to the disc
Please go to the user manaul page [11] & [55] for details. All of it cannote be typed here as the format doesn't allow me to do so. If you haven't its user manaul with you now, send your email address to me by Fixya. I'll send a copy of it to you by return mail. OK.
Panasonic... • Answered on Jun 30, 2011
Page 57 of the operation manual suggests a list of language codes (worth a shot) - using your DVD recorder's remote numeric buttons, and pointing it at the unit while on, enter 6 9 7 8 (English) Japanese is 7 4 6 5
Below is the language code list for this model ONLY. (from page 57)
Abkhazian: 6566
Afar: 6565
Afrikaans: 6570
Albanian: 8381
Ameharic: 6577
Arabic: 6582
Armenian: 7289
Assamese: 6583
Aymara: 6588
Azerbaijani: 6590
Bashkir: 6665
Basque: 6985
Bengali; Bangla: 6678
Bhutani: 6890
Bihari: 6672
Breton: 6682
Bulgarian: 6671
Burmese: 7789
Byelorussian: 6669
Cambodian: 7577
Catalan: 6765
Chinese: 9072
Corsican: 6779
Croatian: 7282
Czech: 6783
Danish: 6865
Dutch: 7876
English: 6978
Esperanto: 6979
Estonian: 6984
Faroese: 7079
Fiji: 7074
Finnish: 7073
French: 7082
Frisian: 7089
Galician: 7176
Georgian: 7565
German: 6869
Greek: 6976
Greenlandic: 7576
Guarani: 7178
Gujarati: 7185
Hausa: 7265
Hebrew: 7387
Hindi: 7273
Hungarian: 7285
Icelandic: 7383
Indonesian: 7378
Interlingua: 7365
Irish: 7165
Italian: 7384
Japanese: 7465
Javanese: 7487
Kannada: 7578
Kashmiri: 7583
Kazakh: 7575
Kirghiz: 7589
Korean: 7579
Kurdish: 7585
Laotian: 7679
Latin: 7665
Latvian, Lettish: 7686
Lingala: 7678
Lithuanian: 7684
Macedonian: 7775
Malagasy: 7771
Malay: 7783
Malayalam: 7776
Maltese: 7784
Maori: 7773
Marathi: 7782
Moldavian: 7779
Mongolian: 7778
Nauru: 7865
Nepali: 7869
Norwegian: 7879
Oriya: 7982
Pashto, Pushto: 8083
Persian: 7065
Polish: 8076
Portuguese: 8084
Punjabi: 8065
Quechua: 8185
Rhaeto-Romance: 8277
Romanian: 8279
Russian: 8285
Samoan: 8377
Sanskrit: 8365
Scots Gaelic: 7168
Serbian: 8382
Serbo-Croatian: 8372
Shona: 8378
Sindhi: 8368
Singhalese: 8373
Slovak: 8375
Slovenian: 8376
Somali: 8379
Spanish: 6983
Sundanese: 8385
Swahili: 8387
Swedish: 8386
Tagalog: 8476
Tajik: 8471
Tamil: 8465
Tatar: 8484
Telugu: 8469
Thai: 8472
Tibetan: 6679
Tigrinya: 8473
Tonga: 8479
Turkish: 8482
Turkmen: 8475
Twi: 8487
Ukrainian: 8575
Urdu: 8582
Uzbek: 8590
Vietnamese: 8673
Volapük: 8679
Welsh: 6789
Wolof: 8779
Xhosa: 8872
Yiddish: 7473
Yoruba: 8979
Zulu: 9085
If you do not have your original instruction manual, you can download one FREE from the following link
Refer to the page I suggested to be doubly sure. Hope this helps a bit. Keep the document for future use as required.
It might not help, but give it a try, it won't damage anything.
Panasonic... • Answered on May 27, 2011
You could try using a DVD lens cleaner (wet or dry type, whichever is available; but it MUST be the manufacturer's recommended DVD lens cleaner (or suitable equivalent) - do not use CD/DVD generic cleaners, they might be cheaper, but these do not work and may damage the unit).
If after following the directions on the pack, the recorder still shows U11, then the drive is probably on its way out. Considering the cost of a new DVD-RAM drive is around $300 or so, plus labour (if applicable), it may not be economical in the long term.
Nevertheless, try cleaning the laser lens (either with the DVD cleaner discs), see how you go. I usually try to avoid opening drive units up in cases of cleaning, however, I have found short bursts of compressed air through the drive from front to back usually solves most dust-related problems.
Panasonic... • Answered on Feb 13, 2011
If u can't play many of the DVD discs from Hollywood movies,Useally the disc itself the problems or the DVD recorder laser eye it bad.Tries websites like Amazon.com,Ebay.com buy a DVD cleaning kit.Put the disc in follow the directions,clean the laser eye data reader.50/50 chances will solved the disc not reading problems.If not the Laser eye is problems the unit not worth fixing buy a new one.DVD players are not woth the fixing of the Tech. prices.
Panasonic... • Answered on Dec 15, 2010
Hi,on your vcr and dvd you should have scart sockets,on the vcr connect a scart lead in the one marked av1,on the dvd connect the other end to the scart to the one marked av2.Now on the dvd select the channel av2 using the input button on the r/control.Now all you have to do is put the vcr on play and the dvd on record.I hope thi helps
Panasonic... • Answered on Dec 15, 2009
Panasonic DMR-E30 DVD Recorder Logo
Popular Tags
37 questions posted
Top Panasonic Televison & Video Experts
Demonic-2011
Demonic-2011
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
always get u11 code when using blank dvd
  • Televison & Video
