20 Most Recent Soyo Atlas DYLT3212 32 in. HD-Ready LCD Television Questions & Answers
i have a 32inch prive remote that dose not work how can i get one or find a code or the replacement remote
Soyo Atlas... | Answered on Dec 03, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Soyo Atlas... | Answered on Jun 13, 2017
Can`t find a remote for my 32?nch prive tv..HELP
Soyo Atlas... | Answered on Dec 30, 2016
Backight tubes are inside the panel.
Soyo Atlas... | Answered on Aug 10, 2012
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
if you do find the code, help me out. thanks
Soyo Atlas... | Answered on Jul 13, 2012
no manufacture has that brand in the code list. but soyo did come out with their own remote that will work satellite/cable boxes. Go on their website. www.soyo.com
Soyo Atlas... | Answered on Apr 08, 2011
unplug it from all sockets and power lay it on its back for 30 mind then plug back in it should work fine
Soyo Atlas... | Answered on Dec 10, 2010
The only option you have left is to do a code search. It varied depending on which Charter Remote you have. I found 5 different remotes for them so instead of putting directions for 5 different remotes I am posting the link to charter. Click the link, scroll down and you will see 5 remotes with set up and user guides for each. If you have problems repost here with your remote model and we can help.
http://www.myaccount.charter.com/Customers/Support.aspx?MenuItem=2&tab=tabeugd
Soyo Atlas... | Answered on Oct 19, 2010
Power supply module will be the first place to look, need to find out if it has blown fuse, burnt parts, etc.
Also look for caps with any leaking/bulging top.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Soyo Atlas... | Answered on Jun 14, 2010
Try pressing the ch+ or input button. Some inexpensive models have that luxury.
Soyo Atlas... | Answered on Sep 18, 2009
you have to use the remote and hit the input button , look at the back of the tv where you plugged the cables in, it will tell you what input it is plugged into, chang your input to that one on the tv- using the input button
Soyo Atlas... | Answered on Jan 10, 2009
you need to change your resolution on the computer look in the desktop right click select properties , select settings, play with the resolutions until you find one that is ok, select advanced, then select displays adjust the refresh rate to some place between 60 and 75 hz, if it doesn't work wait it will return to the previous setting if it works select ok and you have the video setting as good as they will get. hope this helps
Soyo Atlas... | Answered on May 28, 2008
That means there are no more updates for that TV. You might want to get a newer TV.
Soyo Televison &... | Answered on Jul 11, 2019
Go to home setting on remote. Go to audio settings on tv. Adjust sound from there down to suitable level.
Soyo Televison &... | Answered on Feb 01, 2019
Soyo Atlas DYLT3212 32 in. HD-Ready LCD Television Logo
27 questions posted
Top Soyo Televison & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Televison & Video
Most Popular Question
prive lcd tv remote codes
  • Televison & Video
