20 Most Recent Soyo Crystal DYLT032B 32 in. LCD Television Questions & Answers
Look at the power supply for bad solder joints, burnt parts, bad capacitors first.
http://en.wikipedia.org/wiki/Capacitor_plague
Soyo Crystal... | Answered on Oct 30, 2012
Very bad for the TV, don't do this!
Got the remote control? Switch on or off (full operation) from Standby with it and just use the main manual switch on the TV for, say, morning ON for the day and evening OFF for the night.
Soyo Crystal... | Answered on Sep 21, 2011
Hi, I am not sure on this one (as i'm based in the uk) but it sounds like your cable box (if its seperate to the tv) has gone into 4:3 screen mode if you can get into the menu of the cable box perhaps you can change the setting back to16:9 widescreen or perhaps there is a button on the remote control for changing the screen view.
If not perhaps theres a setting in the tv's picture menu where 4:3 mode is set instead of Auto or 16:9
Sorry I can't be of more help and hope this solves your issue.
Soyo Crystal... | Answered on Feb 11, 2011
Hello memory maker, hi, cannot tell if the capacitor is the cause, but what you can do is measure the secondary AC voltage from the main transformer, there should be a 600V ac reading for normal operation on a 220Volt AC main line. A missing secondary voltage means the problem is the primary section where the switching is done, check for the following. 1. Fuse 2. Rectifier Diodes (use a multitester device) 3. Switching transistor(s) 4. Open Low value resistors. 5. Switching regulator ICs (this needs replacement, be it good or bad OR use an Oscilloscope to find the pulse from the oscillator section)
These are all hard work, simplify by replacing the entire Power Supply board.
Soyo Crystal... | Answered on Feb 02, 2011
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Soyo Crystal... | Answered on Jun 30, 2010
Hello there...
Check its sleep settings. Someone may have hit the sleep timer and have set it to about 10 seconds. If that still doesn't help, please post a reply here.
Soyo Crystal... | Answered on Nov 08, 2009
sounds like you a convergenc4e failure, do u have a extended warranty on the tv, this p[rblem can cost upwards of $600 to repiar
Soyo Crystal... | Answered on Oct 08, 2009
What do you mean by explosive change in loudness? The volume goes up and down by itself?
Soyo Crystal... | Answered on Mar 04, 2008
That means there are no more updates for that TV. You might want to get a newer TV.
Soyo Televison &... | Answered on Jul 11, 2019
Go to home setting on remote. Go to audio settings on tv. Adjust sound from there down to suitable level.
Soyo Televison &... | Answered on Feb 01, 2019
Soyo Crystal DYLT032B 32 in. LCD Television Logo
20 questions posted
Top Soyo Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Televison & Video
Most Popular Question
power in standby
  • Televison & Video
