20 Most Recent Protron PD-007 DVD Player Questions & Answers
Remote Control code for DVD Protron PD-800
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. https://homenol.blogspot.com/ https://remotesearch.blogspot.com/ https://electronicshelponline.blogspot.com/ https://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
2/5/2018 12:38:29 PM • Protron PD-007... • Answered on Feb 05, 2018
I have a Phillips older model TV with red, white
You probably just need to select the input from the TV setup or the remote. Most have multiple selections such as "antenna" "cable" "HDMI" or AUX... flip through them until you find the one that works. Good luck.
8/28/2013 1:39:45 AM • Protron PD-007... • Answered on Aug 28, 2013
3answers
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
9/10/2012 8:08:24 AM • Protron PD-007... • Answered on Sep 10, 2012
What channel should the tv be on when hooking up my dvd player?
HelloHook the TV to DVD player with AV cable. Select AV from the TVs menu. This is the pciutr of the AV cable. It will have three wires, and you should connect it with your DVD and TV according to its instructions. OK.12_18_2011_1_57_53_pm.jpg
12/18/2011 1:58:40 PM • Protron PD-007... • Answered on Dec 18, 2011
I have to insert the
It could be that the laser is going faulty, or there is dirt/dust on the lense, or that the carriage carrying the laser is loose and not tracking correctly. You will need to open the DVD player and look at the laser unit to see if anything can be cleaned or adjusted.
2/20/2011 7:45:31 PM • Protron PD-007... • Answered on Feb 20, 2011
Picture rolls when playing disc
Check all the connections on the back of player and tv.
does not sound to hopeful.
have you tried another player on the tv and what is the result ?
2/10/2011 7:34:42 AM • Protron PD-007... • Answered on Feb 10, 2011
Does the audio output support surround sound.
It should support Surround Sound as the standard has been around for quite a few years now.
Dolby digital and DTS should be supported.
If yours is working, your doing well. I've read the reviews and consider you fortunate that yours works.
The interesting thing about solid state electronics, is that if it works for about 90 days it will probably work for quite a few years after. So you are lucky people,
Have a Happy new year,
If your have any more questions, just ask me.
Mark
1/2/2011 1:44:34 AM • Protron PD-007... • Answered on Jan 02, 2011
Reset parental code....when i put in a R rated
the factory code is 0000 if this does not work the unit will need reseting this is done by holding down the men
12/28/2010 11:52:55 PM • Protron PD-007... • Answered on Dec 28, 2010
Looking for a remote that will work with model
Philips universal remote my model is CL035A DVD code 0194.
11/17/2010 7:04:38 PM • Protron PD-007... • Answered on Nov 17, 2010
0answers
When playing DVD movies, after watching about 75%
Hi, the problems here can be caused by a couple of things. Assuming you have tried playing a couple of DVD's back to back, it sounds like there is runout on the disc (wobble) which is preventing the pickup from tracking the outer edge of the disc.
it sounds like there may be a particle stuck to the spindle table(the round table that the disc sits upon).You may need to remove the disc clamp to gain access to it - just run your finger lightly around the top edge of it to clear it - don't be tempted to touch or look into the laser pickup - you can be permanently blinded.
8/13/2010 2:36:32 PM • Protron PD-007... • Answered on Aug 13, 2010
2answers
No color
This sounds like you need to set the regional settings on the DVD player.
Most DVD players have regional settings on them which are NTFC, PAL and also Multiregion.
These settings will be in the On-screen-menu in one of the settings. If you switch between these settings you should bring back the colour to the picture as well as the sound.
Having a tinker with the settings usually sorts out the problems. Other causes are bad or badly seated leads. A good idea will be to check the leads are well connected and are in the correct positions.
Please post back if there is anything else.
7/27/2010 12:14:36 AM • Protron PD-007... • Answered on Jul 27, 2010
When i put a dvd in the dvd player it loads and
it has a bad laser or will not read certain video farmats. most likely the laser in my dealings with proton. bye
11/9/2009 8:38:28 PM • Protron PD-007... • Answered on Nov 09, 2009
I lost my manual for my Protron DVD player and I
Hi
Thanks for using FixYa. You can follow these images for details as how to connect the cables with your TV--
Also see this image if you are using co-axial cables--
Also see this link for detailed info--
DVD player and TV hookup info.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
9/1/2009 5:14:06 PM • Protron PD-007... • Answered on Sep 01, 2009
Need to hook up to tv
use the colored lead (RC) cables to connect from dvd player to your tv, it is color coded so you cant go wrong, then select av on the tv to watch dvd, if it can connect to tv with rc cable then you will need an adapter to connect dvd through antenna jack ok
6/29/2009 2:34:15 PM • Protron PD-007... • Answered on Jun 29, 2009
I have sound but no picture
it does not support pictures
6/21/2009 1:37:49 AM • Protron PD-007... • Answered on Jun 21, 2009
Protron PD-007 DVD Player Logo
37 questions posted
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Protron Televison & Video
Most Popular Question
when put dvd in dvd player loads
  • Televison & Video
