20 Most Recent Protron PLTV-37 37 in. LCD Television Questions & Answers
"Only Effect for TV" message blinking on top left of screen
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
10/29/2021 7:10:53 AM • Protron PLTV-37... • Answered on Oct 29, 2021
2answers
I am getting no picture nor sound only red light...what can I do?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
10/17/2019 7:47:24 PM • Protron PLTV-37... • Answered on Oct 17, 2019
Sound but no Picture
Most likely it is the board on the lcd panel. The first question though is, can you get menus? If yes, it is the input module, if no, most likely the panel controller board. There are several makes of panels in these sets, so once diagnosed, we would need to know what panel you have to help further. I can help you figure that out once you let me know if you get menus or not.
9/6/2014 9:59:19 PM • Protron PLTV-37... • Answered on Sep 06, 2014
What does a orange not blinking indcator light mean?
For your TV the power light will be red when the TV is turned off using the power button on the top of the TV. Press the power button on top of the TV if that does not work then try turning the power off at the power switch on the bottom of the TV then turn it back on after a minute ior so and see if you can turn it on using the power button.
8/5/2014 4:04:08 PM • Protron PLTV-37... • Answered on Aug 05, 2014
Could not set up dish dual receiver
Omar Garcia Santiago, I'm going to need some more details as to what the issue is. What model number is it? Is this a replacement or for a new account? Are you having trouble with the hookup or are you getting any error messages on the TV screen?
4/11/2014 10:41:19 PM • Protron PLTV-37... • Answered on Apr 11, 2014
My proton tv will not turn on
Check and replace its main power supply regulator [SMPS] as card basis. Contact any service technician for assistance. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/24/2014 10:40:30 AM • Protron PLTV-37... • Answered on Mar 24, 2014
0answers
I have a dark line in the middle of my sreen how
LCD panel is bad, I have seen a lot of these sets do this, part is not availible
11/23/2013 5:48:10 AM • Protron PLTV-37... • Answered on Nov 23, 2013
Programming remote for blu ray player
You can't program any universal remote control with any blu-ray players' blu-ray region without its original remote control. You can synchronize its DVD region, with a universal remote control. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
10/17/2013 6:12:51 AM • Protron PLTV-37... • Answered on Oct 17, 2013
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
9/5/2013 8:53:50 PM • Protron PLTV-37... • Answered on Sep 05, 2013
2answers
Is it posible to change the aspect ration on my 37" Protron LCD
Select a different aspect ratio from the menu.
8/28/2013 5:45:26 PM • Protron PLTV-37... • Answered on Aug 28, 2013
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television. Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound. Depending on the type of problem you encounter, there are several options available to you to solve it. Power Issues Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket. Unplug the television and plug it in to another electrical socket. If the one it is plugged in to currently is bad, the television does not receive power. Try turning the television on with the remote. If that does not work, try turning the television on with the power button on the TV's front panel. If that works, then remove the battery cover from the remote. Remove the current batteries and replace them with fresh batteries. Picture Issues Check the video cables. If they are loose or disconnected, securely connect them. Adjust the television's brightness. If the brightness is set too dark, images on the screen are extremely difficult to see. Check the power indicator on the front panel of the television. If it is red, the television is in power-saving mode. Simply press any button on the remote to bring the television out of power-saving mode. Audio Issues Check the audio cables. If they are loose or disconnected, securely reconnect them. Turn to different channels and adjust the volume. It is possible that some channels are coming in quieter than others. Access the audio options from the main menu. Check what audio setting the TV is at. If it is set to "Mono," change it to "Stereo." http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37 Specifications for Proton CS-37 / PS-47
8/9/2013 5:36:50 AM • Protron PLTV-37... • Answered on Aug 09, 2013
2answers
No Picture (power indicator does not light up)
I have a Protron 37: LCD TV. The power indicator does not change to green (the red light is showing) and the TV will not turn on, either by remote or using the power button on the TV. The TV is about a year and a half old. Can you please help me?
Thanks
1/29/2013 5:40:26 AM • Protron PLTV-37... • Answered on Jan 29, 2013
Control panel
The remote or the Tvs IR sensor are the two most likliest causes of that issue.
11/4/2012 11:49:05 AM • Protron PLTV-37... • Answered on Nov 04, 2012
Protron PLTV-37 37 in. LCD Television Logo
187 questions posted
Top Protron Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Protron Televison & Video
Most Popular Question
turn off adult thing put every
  • Televison & Video
