Brother HL-5240 Laser Printer Logo
Anonymous Posted on Jan 21, 2010
I have a brother hl-5240 printer and I am trying to print label where do I put the label? the printer paper red light comes whe I put the label sheet in the regular paper tray. I cannot find another place to put the label sheet. Help
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Jan 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1130989
Points
8732
The label sheet needs to go in the front slot, if there isn't a slot on the front, then you grab the notches on each side of the front door and just open the feed tray.
Testimonial: "thank you for the information. I has no idea there was a special slot inside the cartridge door. I will try it. "
HOW TO PRINT ENVELOP IN BROTHER HL 5240
straight paper path. take out tray and toner.. pop down back the paper will be in one of the places.. check for nicks or damage to leading edge of the paper. If its labels get back to us.
I have a Brother HL-5240, status light red, paper light flashing. Plenty of paper in the tray
Ether the paper sensing lever is broken or there is dust accumulation or paper fragments inside the optical sensor.
My Brother HL-5240 printer constantly has the paper light on even though there is paper loaded
You probably printed a document that was forced to the manual feed. Place some paper there and it should print. Go to your printer preferences and set the default tray to tray1 instead of Auto.
2helpful
HL-5370DW laser printer will not print labels. When given label number, red light comes on.
It probably wants you to insert label sheet thru the envelope slot in the front, using the cassette peels the labels off of the sheet. If there is nothing in the front slot when you select labels it will show an error.
2answers
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
4helpful
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
1helpful
Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
Printing envelopes and labels
I foubd the Brother website to be very helpful with my label and envelope printing:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_007.html?reg=us&c=us&lang=en&prod=hl5240_all&Cat=4
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Norman Weimar
Norman Weimar
k24674
