SOURCE: Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print - replace fuser
LSU(laser) or boards rarely cause issues
SOURCE: Bad transformer on Inverter Board
for me I think I'm gonna try Decision One a certified Dell fixer upper. I looked at my inverter and there were no burns that I could see. My problem is different from Headstrongs come to find out. Dell w3201c is the model number, it has samsung on parts under the hood....
good luck
SOURCE: Black Line bottom of LCD Monitor
May be a manufacture defect or the Screen goes wiped out during transportation.
Call to the support for warranty issues immediately.
Regards
Ellin
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
SOURCE: Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Basic LCD monitor troubleshooting guide:
