Question about Samsung ML 2010 Laser Printer
Faint vertical lines on Samsung ML-2010
Samsung Laser printer ml-2010. New toner cartridge installed since a few months ago, printed about 500 pages since then but lately having 2 faint white vertical lines from top to bottom on a dark background. Already shook the toner cartridge to spread the toner but to no avail. The lines are always at the exact same spot. Could it be some of the laser LEDs that are going bad? Total printed pages so far 1744.Thanks for any info.
Posted by TheAlien on
  • TheAlien Apr 11, 2009
    This is an original Samsung replacement cartridge. But I'll try another one anyway. Thanks!
  • TheAlien Jul 31, 2009
    I've solved my problem by cleaning the doctor blade in the cartridge. It's a delicate operation, but done carefully it's possible and it makes a big difference! I've followed the step-by-step instructions on this page to get to the blade.
    http://copiertechdepot.blogspot.com/2007...
Anonymous
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Posted on Apr 11, 2009
I have Samsung ML-1666 Laser Printer. I am getting
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jun 02, 2012 | Samsung Office Equipment & Supplies
Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
there must be waste toner in your toner cartridge
the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
Jan 26, 2011 | Samsung ML 2010 Laser Printer
How can i do 0 for ml-1640 page count ,and want to resetpagecount
You have to flash the printer with the fixed firmware and it will never ask you again for a new toner cartridge :) it is a 1 minute job for me and i charge my Local customers 10 Euro mostly because it has to be done just once and then you just refill the cartridge without doing anything else ( this is just an explanation - i don't want your money)
Jun 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Very faint printing in xerox 3117 laser printer
my ml 2010 never has printed as dark in the centre of the page even when the toner is full?
Sep 02, 2008 | Samsung ML 2010 Laser Printer
Fain printing
I'm using remanufactured toner provided with my ML-2010 by Discount City when I purchased the printer and I'm having the same problem.
I have used non OEM toner in other laser printers also with disasterous consequnces so I think you'll have to 'bite the bullet' and purchase a new Samsung toner cartridge unless you can find out who manufactures the cartridge in which case you might be able to souece one directly avoiding the extorionate mark up.
Jun 19, 2008 | Samsung ML 2010 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
1,433 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
