If there is no blockage in the pump and the test you have already done indicates a minor buzzing or hum,the drain pump is bad.
You could also examine the impeller in the pump to see if it is worn or otherwise damaged.
Just replace Pump once they are bad its hard to even get what you need to even try to fix , you are better off with a New Pump with warranty.
Do you see any Error Message on that?
If yes, let me know the same without Reading Further.If not, it might be due to many reasons. You need to properly Investigate. As, you never provide me with all Details, the Best i could do is to Offer you complete Guide.
Before that, Kindly check the Below procedure to Test Pump :-
http://www.acmehowto.com/howto/appliance/washer/check/pump.php
The Guide is :-
It spins, but doesn't pump
If
your washer spins but doesn't pump the water out, the drain line is
probably clogged. In many washers, a small sock or other piece of
clothing can get between the clothes tub and the outer tub that holds
the water. If the clothing gets between the tubs, it may then get into
the drain hose that's attached to the pump--or even into the pump
itself. If it's in the pump, you need to remove the hoses from the pump
and pull the item out.
To
remove the sock from the outer tub port, open the washer's main access
panel and remove the large-diameter rubber hose that connects the pump
to the bottom of the outer tub. Then, using needle-nose pliers, try to
grab and remove the clothing through the port.
Sometimes
you can't remove the stuck clothing from below. Then you have to remove
the agitator, top of the outer drum shield, and inner clothes tub. This
isn't easy to do--and you may need special tools--so you might be
happier getting a qualified appliance repair technician to do the job.
If
the drain line isn't plugged, the problem may be with your pump. Even
if the pump appears to be turning, the internal impeller may be broken.
If so, you need to replace the pump.
It doesn't spin or pump
If
your washer doesn't spin or pump water out but the motor is running,
your washer probably has a frozen pump pulley. If so, you need to
replace the pump. To check the pulley, remove the pump from the washer
and try to rotate the pulley manually. If it doesn't turn freely--if
it's frozen or stiff--replace it.
It pumps, but the water returns
If
the water that pumps out of the machine goes back into the machine
after the spin cycle, your washer may be siphoning the water from a
laundry tub that has a slow drain, back into the washer. The usual
remedy for this is to improve the draining of the laundry tub. (Is
something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
ND stands for no drain. If the hose is clear
then you have something stuck in the drain pump. You can tip the unit
back and remove the lower panel. The drain pump sits in the front right
corner.If the problem persists, more likely it would be Bad Pump.
Hope i helped you.
I get the ND code on the washer. I understand from the owners manual that is not draining, correct?
I just found a quarter in the drain hose from the washer to the pump. The pump still does not work though
I am going to order a new pump. Hopefully that wll solve the problem. If not, I will be back.
Thanks!
Thanks!
