Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4) Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to reinstall linksys wireless-G nb adapter 2.4 GHz onto my computer. My computer crashed and i had to reinstall the programs
Anonymous
Level 3:
  • Master 591 Answers
  • Posted on Nov 09, 2009
Anonymous
Master
Level 3:
Answers
591
Questions
Helped
160171
Points
1421
Here is the starting point for your WPC11 PCMCIA internet card:
http://www.linksysbycisco.com/US/en/support/WPC11/download
1helpful
DOWN LOAD DRIVE
1. Use a computer that has internet access and go to http://support.linksys.com/en-us/support/adapters/WMP11.
2. Click Dowloads Tab and download that driver that you need.
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
1helpful
I have got Linksys wireless adapter WUSB300 and my Pc seems to crash frequently.
do u mean every since u installed the adapter ur computer has been crashing if so then its either bad or u need to reinstall the driver for it
Describe your Linksys 2.4 GHz 802.11b Wireless - B PCI Adapter Problem where is the network key locaded
The network key is actually programmed into the wireless access point you are trying to connect to. You need you provide your network connection with that code in order for the adapter to get permission to connect to the router.
Unless you are connecting to an unsecured connection - then you don't need a key at all.
1helpful
I have defined 2 networks, one for the G and the other for the N channel, only the one for the G gets connected
You have WRT610N dual band router . it works on both 2.4 GHz and 5 Ghx bands at the same time.
Both the bands are N bands.
2.4 GHz and 5 GHz band are capable of working on N signals.
Now on your computer you are able to see only the 2.4 GHz signals but not the 5 GHz signals.
To see the wireless signal on the computer , your computer should have 5 GHz compatible wireless adapter.
If you have 2.4 GHZ adapter on your computer then you won't be able to connect to the 5 Ghz signal.
Open the Device manager and under network adapters you will see the wireless adapter. Check if it is dual band wireless adapter.
Click here for more information
I have a 2wire 802.11g usb wireless adapter. I
yes it would you just need to place the 2wire on a bridge mode then configure the linksys
1helpful
2answers
Linksys Wireless-G 2.4 GHZ two computers distribution of Mbps
unfortunately wireless is slower. i wouldn't worry though as 100mps is what windows always says but this itself is not accurate as your isp is probably even less than 18 mbps.
1helpful
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Cannot get my USB wireless-G adapter to work
hi mark, if the wieless G is already installed don install the linksys cd,  in ur working computer go to the lynksis page and set the wireless to manual and to channel 9 then in the non working computer  open the wireless g utility and look for options such as let this tool mange wireless if ticked uncheck it, or let windows manage wireless check the option close that box then start-control panel-network connection-wireless network connection-right click on it -view avail wireless networks and slect ur network and click to connect enter the wireless key and u will be connected to internet
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
