20 Most Recent
Linksys 2.4 GHz 802.11b Wireless - B Notebook Adapter (WPC11 v. 4) (LINKSYSWPC11V4) Questions & Answers
Where is the wps button on a linksys router
Depends on the on router. The button should have a picture of an antenna on it or say WPS. Pres it and the light will flash then press the wps feature button on the device you are connecting. If this is a Linksys EX0000 model it should be on front and center on the top of the router.
How do i find my router username and password
The easy way to get password is to left click on Internet access bars near time on computer.When box appears showing wireless connections right click on your name connected to.In drop box choose properties then under security click show characters to reval password.
I don't have my user name and password for my
If you have the CD that comes with the adapter then you can try
uninstall Linksys software and install only the drivers of the adapter.Remove
the Linksys Adapter and un-install the Linksys Software from Programs
menu. To re-install the Drivers insert the Linksys Setup CD into your
CD-ROM drive. When the Welcome screen appears click Exit. Connect your
USB adapter to the computer. When the Found new Hardware Wizard window
appears, click Install the software automatically (Recommended) then
click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You
can also download the latest drivers from Linksys website on any other
computer. Save it on a Flash drive and transfer the drivers on your
computer.
I had a dell netbook
This is caused by setting the encryption to WPA-RADIUS instead of
WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.
Switch the encryption to WPA-PSK (pre-shared key) on both ends and it
will work.
Can not connect my wireless
what is the Operating System?? Windoze, LINUX, MAC, etc... what is the type of Access point you connect to???, does it work with an other computer??? or other device??? you have to elaborate on your setup if you want us to help... what is your ISP (Internet Service Provider)??? do you use a router???, if so what make and model???, whas it working befor??? what did you do when it stopped working??? updates??? etc... there could be a 10000000 things to prevent stuff from working we need to narow it down a bit...
I don't have the
If you have a usb drive you can download the drivers to the usb drive and then install them on the notebook.
How do you configure a
let me tell you its very easy.
Follow these steps to connect your Linksys adapter to available wireless connection:-
1.With this adapter you must have received a disk of driver for this adapter.
so install the drivers disk first.
2.Once the driver disk install then now you can search for available wireless network name.
To search wireless network in xp:-
start>>control panel>>network connection
now look for your wireless network connection.>>>right click on it>>>left click view available wireless network>>>here you can see the available wireless network name and now try to connect to your network name
Follow these steps for vista and window 7:-
Click on start>>Above start you will have search box>>in the search box type connect to
I need Linksys Wireless WPC54GS-RM
You can find the drivers here:
http://homesupport.cisco.com/en-us/wireless/lbc/WPC54GS
Select the DOWNLOADS tab
Pick the hardware version on the card
Download the setup wizard, unzip and run it.
Even with the password, i
You may have to settle for WEP passcode or none at all. The older technology may not understand any type of encryption. An alternative means of protection for you may be something called mac filtering. You will have to do the research. Good luck.
How can I get the wireless adapter to work with my
If the router is too new it may not be backwards compatible with wireless b standards. Otherwise check the router settings for something like "wireless b mode" adding older technology will slow down all devices on the wireless network. It may be easier to find a used wireless g pcmcia card online.
I have an old laptop
Most of the newer routers use a newer type of encryption (WPA or WPA2) which is not supported by older 802.11b hardware.
Either set the Linksys router to use WEP encryption, or get a newer 802.11g card for the old laptop which can use WPA or WPA2 encryption.
Older versions of Windows XP also need to be upgraded to Service Pack 3 or apply this patch:
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=662bb74d-e7c1-48d6-95ee-1459234f4483&displaylang=en
I have an older computer
Yes you can definitely download the driver from a working computer and save it to a flash drive and then transfer to the computer where you want to install the adapter.
You can download the driver for it from the manufacturers web site and once done you can continue with the installation of it.
