Pioneer PD-M406 6-Disc CD Changer Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Found small plastic piece,cd will not pull out cd to play (think this plastic piece is why) where does it go on the player?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 277 Answers
  • Posted on Nov 01, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
277
Questions
0
Helped
53513
Points
818
Prob from the drive shaft someone tried to push the cd in sy
2answers
Yamaha PF-50 Turntable
When I pull the play lever on my Yamaha PF 50 turntable nothing happens. Platter doesn't spin and it does not play
Hyundai i30 cd player
hi Squeakylyssa .This goes for all cd players.
If a CD is skipping, first ensure that the disc is working properly by checking to see if it plays on another device. If so, you'll have to uncover the problem in your CD player. Some common problems include: broken parts in the device, physical damage to the CD player, dirt within the player or, most commonly, damage to the lens.
Before you do anything with the CD player, it is important to remove the batteries and disconnect the device from any power source. Wait half an hour before you begin cleaning the device.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. Place a small amount of your cleansing solution on a cotton swab or other applicator that came with a lens cleaning kit; as an alternative to lens cleaner, you can also use isopropyl alcohol. Rub the cotton swab in very light and small circles against the lens until it is clear. Allow the lens to dry, and then proceed to test the CD player. If the CD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.
A CD player has a few hardware components that may be causing your discs to skip. Unscrew and open the case of the CD player to locate the read head and potentiometer. Depending on the type of device you have, you may need to remove the bottom cover to gain access to the soldered side of the electronics board - if so, you will need to remove the whole board before you can proceed. In single-play designs, you should be able to find 3 or 4 screws that need to be removed to enable you to take out the whole optical deck. There may also be a grounding contact under the deck held in with one screw. Make sure you replace this exactly as you found it.
If your player spins for some time without finding the list of tracks and keeps returning some kind of error message once you place a CD in the player, there is a most likely a problem with the read head. The read head is represented by a small square piece that has a plastic disc sitting on top of it. Using a flathead screwdriver, adjust the plastic disc to realign the read head. This process requires you to plug in the device and hit play and stop until these adjustments fix the CD player. Make sure to put the case back on the CD player each time you test it to avoid any electrical shocks.
The potentiometer, which is positioned directly above the laser, may also be misaligned. Usually this is represented by a small square piece that has a plastic disk on top. The disk has a slot adjustable using a small flat head screwdriver. Before making any adjustments, mark the current position of the potentiometer using an indelible marker pen so that it can be returned to its initial position if need arises. You will need to gently adjust the potentiometer and locate the position where the CD player recognizes the disk again and plays it without skipping. Since this is more of a trial and error process, small rotations of plus/minus 30 degrees of rotation are usually recommendable. For safety, put the case back on the CD player each time you test. If you are happy with the performance after the adjustment then put the case back on and you are ready to rock.
The plastic piece inside the cd player door is broken so it won't play cds. Can this be fixed or rigged?
If the piece can be found then you can use SUPERGLUE to fix it in place. Use a thin metal strip wire to reinforce the stub and also using the glue to stick it well. Use a soft filer to clear the dried glue.or use a emery paper to make it fine.
2helpful
My Kenwood DP-j1070 100 changer is finding cds but not playing anything - there seems to be a spring loose on the loading arm - and not quite sure how to repair - thinking this may be the source of the...
The piece of plastic that held the spring in place probably broke off like mine did. I repaired it by drilling a small hole under the bottom of the slot in the arm and connected it with a piece of solid wire.
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
1helpful
2answers
Cd will not go in
its a small piece of plastic broke it holds the chrome pull on the inside that broke and now its not pulling enough pressure down on it to play right or the ejecting slider broke which is a wierd looking black plastic part on the side of the disk drive
3helpful
2answers
CD Player does not eject CD
Just took one apart tonight. Same problem, put in cd-played fine-push eject then click click click.
2004 nissan sentra 140 watt single cd player/radio.
This dash comes apart by pulling the top of dash (with the tray) straight out the clips should release. the bottom part had to be pried a little, then remove four screws and slide out the radio still attached to the mount and dash etc. One screw holds on the top of the stereo. After removing the screw you must pry the top off. Now it gets a little tricky, you must remove the cd player portion, however there are 5 tiny springs holding it down to some pads. The two springs in the rear are under a piece of the stereos frame held on by two screws, I had to use various sizes of tweezers to get the springs off. Lift the player out of the radio about an inch, you will see one 1/2" ribbon in a connector, the top of the connector slides out along the ribbon to release. The other ribbon about the same size plugs into a small daughter board in the radio, it just pulls out and pushes in (you can feel it is reinforced). once out turn it over and you will see what would be considered a gearbox, (small white gears in a see through case) one of the corners of this case has a screw through it. This corner has broken away from the board letting the gears come apart when trying to eject (this is the clicking). I took a soldering iron and melted the plastic back together and put a small amount of 5-min epoxy on for good measure. When putting back into case you can hook up the ribbon cables before all the spring grief and test it out. Mine worked perfectly again. Be care full when putting back together, there are a lot of little micro switches that must be in the correct position) Example, if the cd is ejected the white arm on the right side must be in the correct position. the read head (laser) must be away from the center of the cd. I believe it was easier to put together with it in the cd-in position (without a cd in it) so the laser must be toward the center of the cd. Don't force the laser, use the worm gear to move it in or out. I couldn't put one of the springs back on but it still works fine Good luck, it's not as hard as it sounds
Initial screen shows "OPEN" in the top right corner
I had this exact same problem with my Protron DVD player. It was driving me crazy. I was about to just trash it, cause I was so tired of dealing with it. Then I decided maybe I should open it up and see what the issue is. I am not sure what exactly I did that fixed it, so I will just tell you everything I did. It works great now!! It's as if I know what I'm doing... but I was just playing really.
Here's what I did:
I unplugged it, took off the battery pack, turned it over and unscrewed the four screws holding it all together (one of the screws is located under a sticker that warns about voiding the warranty). Then I turned it back over, lifted the screen back and pulled apart the top from the bottom. It did kinda sound like something might crack as I pulled it apart, but it didn't. I just moved slowly and eventually got the entire thing separated, even the plastic around the hinge area will pop off, leaving just a couple cables connecting the top to the bottom. Again... I am not sure what I did that fixed it. But I found the button that would be located under the right small hinge of the DVD door that tells it if the door is open or closed. I pushed it a few times, thinking at first that something might be missing or broken that should make it work. I blew it out (just because it was opened up and I thought it couldn't hurt). I did notice a small white plastic piece near the back that fell when I had pulled open the entire thing. I thought it had to do with dvd door, but then realized it was the control that told the player if the lid was up or down. It had a wide side and a skinny side, with a flat piece in between. The skinny side actually sticks through the top section I had just removed. It shouldn't have had anything to do with the other problem, and it could have been in place just fine before I opened it up. I did put it back through the hole, using a piece of tape to keep it there while I assembled the entire thing back together. And then I was excited. I fixed it. I'm not sure how, but at least I don't need to buy another one. I don't know if it was me blowing it out, replacing that plastic piece, or playing with the dvd door open button. I would think it is the latter. (when it all apart there are two little black buttons near the back. one is just right of center, and the other is another inch or so to the right of that. the first is the dvd door open button, the furthest right is the one that lines up with the white plastic piece and the hole for lid open or closed).
That is probably really confusing. Sorry. I just explained as best I could. Let me know if further explanation is needed.
1helpful
Kenwood DP-J1070
I have been experiencing the same problem all of a sudden. Almost like it doesn't recognize that there is any information on the disc(s), regardless of whether it is a CD-R or Original disc. As I looked closer, I saw there is also a small spring connected at the top on the swing arm that pulls the CD in (behind disc indicator light) but it is not connected to anything at the other end of the spring. Just hanging there...I've never noticed it before.
1) Have you found a solution to get your CDs to play?
2) Does anyone have a clue what the other end of this spring is supposed to connect to? Or know where I can find a detailed diagram of the pieces on this part of the device?
Thanks!
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
