Refrigerator light doesn't work. the bulb is good and the door switch is good. still no light. model csx 22D
If you have an elect. meter, you can tape the door switch closed, remove bulb, and touch your leads, one to the center tab on the socket and the other to the threaded portion of the socket, where the bulb screws in and you should have 120volts. If you are sure you have no power, unplug it and try and gently pull out the switch. This is the only thing between the light and main power below.The switch only connects to one of the 2 wires and a connector may have burned or come loose.If you have power to one side of the switch to ground, and its taped closed, and have no power coming out the other side, then you have a faulty switch.You can get a socket and or switch at your local appliance parts house. Just take the model, serial, name, and product # if there is one and they can match one up for you. I'm betting its the door switch.
sincerely, shastalaker7
A note for shastalaker7 -
Actually, if you tape the switch closed, you won't get 120 v at the socket - leave the switch 'open', as that is the way it is when the door is opened - it's a normally closed switch. Anyway, I'll try that - I've checked both the bulb and the switch and they are okay. I did buy an appliance bulb recently for my oven, and it didn't work when I screwed it in - fully bottomed out. I discovered the tip wasn't extended far enough - fixed with a dab of solder (cheaper and easier than returning it). So checking the socket is a good idea.
