It was just what u said so had to buy new amp thank u dudes are great darryl
Hello pruittdarryl,
Does the amp turn off when you remove the remote wire? If it does, then wire a toggle switch into the remote wire and just use it to turn the amp on and off. If the amp does not turn off with the remote wire removed, there is probably a short between the 12V+ and remote terminals. In that case, the amp is probably defective. If it is OK otherwise, you could still use it by putting a heavy duty toggle switch into the power wire itself.
Hope this helps.
