20 Most Recent Kicker ZX650.4 Multi-Channel Amp - 480W ZX Series 4-Channel 650W Bridged Remote KickBass Car Audio Amplifier Questions & Answers
Rear left channel makes my speaker pop cuts in and ou at certain settings
Swap left and right speakers. Does it stay with the speakers if so you have a blown or damaged speaker. If not then swap input cables only. If it stayed with the speaker you now know the amp has a bad channel and needs repair. If it swapped again you either have a bad cable or issue with your source unit.
7/26/2016 4:47:04 AM • Kicker ZX650.4... • Answered on Jul 26, 2016
2answers
Amp Power LED Display blinks red and no sound
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. Does the voltage on either the B+ or remote pulse below ~11 volts when the LED flashes?
2/23/2015 11:35:06 PM • Kicker ZX650.4... • Answered on Feb 23, 2015
2answers
I want a reliable system.
if you bought that equipment today then your answer is yes your amp will power the subs but if i was you and you want more bass I would go with a two channel amp or even a mono block amp that will be 1 ohm stable and if you decide to do that you might want to get subs that are dual 4 ohm voice coils and run them in series that will get you 1 ohm of resistance
5/31/2014 11:50:57 PM • Kicker ZX650.4... • Answered on May 31, 2014
Kicker zx650.4 amp turned off and on
could be a couple of things going wrong. could have overheated and shutdown to protect it. could have hand to many incoming wattage/voltage from your head unit and shutdown. could be that the ohms rating on your speakers is to low or that the speakers could have heated up and bumped the guilds and caused it to shutdown. don't know if you know how ohms works. but here is an exp. if you have and have that is rated at 4 ohm stable and that is the lostes ohm recomened for it. and you have two 4 ohm rated subs. you can run them and run them with no problem as long as you don't bridge them. run them off of the same port on the amp. when bridging them it devides the ohms in half. so 2 4ohms would become 2 ohm. 2 8ohm would become 4 ohm etc. if you are running 4 speakers in pair that are 8 ohm each the total together would be 2ohm. hope this helps. try to duplacate the conditions that was going the other day when it shut down same bass settings same song etc and see if it happens again if so try unhooking one of the speakers and try it again if it don't do it it was overloading it if it was overloading and you know its right ohms etc. send it in sorry this is so long.
5/1/2010 5:36:38 PM • Kicker ZX650.4... • Answered on May 01, 2010
Why is my Kicker 08zx650.4 amp turning off in my 98 Deville??
ive been hearing alot of this going on yes you had youre system proffesionaly installed but youre amp is pushing at all its got it must be pushing at 1ohms capacity loud but what you dont realize is that.. do ur home work first some amps say they can handle the power but if you read carefully it would read not stable look up amp on the net before buyin review them first ...but evrything youve got is correct its youre amp it wont burn out but you wont get continous power to ur spkrs ..i recomend installing one amp on each spkr same brand if you prefer in keeping it with a crossover if you dont have one that way they wont over heat and cutt off and you will use less power and get more bass...
2/24/2010 2:39:29 AM • Kicker ZX650.4... • Answered on Feb 24, 2010
My amplifier keep clipping
start with the lowest settings on all the adjustment knobs and turn your radio up to about 3/4 of the volume and go from there
7/6/2009 1:22:26 AM • Kicker ZX650.4... • Answered on Jul 06, 2009
2answers
DHD NTX-3107 Wont turn on anymore.
Hi, Please check that you've swapped out any associated batteries of your amplifier. And also, please double check that you're using compatible fuses as some manufacturers build their machine to only work with their own products like fuses. If all of these things fail, you might need to reach out to the manufacturer of the product if you don't have access to the manual for troubleshooting. Thank you.
10/21/2022 12:49:35 AM • Kicker Car Audio... • Answered on Oct 21, 2022
Kicker CXA 400.1 ...accidentally hooked up + and - backwards now just keeps blowing inline fuse immediately. How can i fix this? Inside amp nothing looks damaged
Send it back to maker for repair.
CX400.1 Mono Amplifier - KICKER
https://www.kicker.com > CXA4001-400-Watt-Mono-C... Using efficient Class-D power, the CXA400.1 features a variable bass boost with KickEQ™, giving you as much as a 6dB of extra bump with a simple turn of the ..
10/9/2022 7:12:08 PM • Kicker Car Audio... • Answered on Oct 09, 2022
I have a taramp 5k and keep burning subs so I am getting new subs from kicker and have a choice of 2k or 3k amps but don’t know which too choose 2k will under power but I feel 3k is just right just do t want to burn no more subs need advice 2 15” l7s subs
Kicker advises not to overdrive the system because it can burn stuff up. Having that much power does not mean you listen to it that loud. It means there is something called headroom in amp range that allows it to supply the needed power for bass response when it has to. There is also the issue of impedence of the speakers and how it affects wattage. Lower impedence impedence results in higher wattage at the cost of heat. There is nothing listed I see that can take all that amp has to offer. Also be sure that the cross over is working to seperate the signals to the speaker.
7/12/2022 1:51:37 AM • Kicker Car Audio... • Answered on Jul 12, 2022
Can Car speakers hook up to house stereo?
Yes but you will need to put them in a wooden box
6/11/2022 7:54:52 AM • Kicker Car Audio... • Answered on Jun 11, 2022
2answers
I have two kicker compc dvc 4ohm 15s in a ported box. Can I hook it up to a Mmats pro audio d700.1 mono amp?
From the information I could find on that amplifier, it is stable at one ohm and provides 700 W RMS at that resistance. With two four ohm dvc subs you can wire them parallel/parallel for a final load of one ohm. 85d7eda6-f8f2-4e4d-8fe5-68f3dc5b1895-qgeb1bdcdbvijzq2zc5badm3-d-0.png
2/27/2022 7:49:45 PM • Kicker Car Audio... • Answered on Feb 27, 2022
Car Audio & Video Logo
9 questions posted
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
kicker 08zx650 4 amp turning off in 98
  • Car Audio & Video
