20 Most Recent Kicker ZX300.1 Car Audio Amplifier Questions & Answers
You have exceeded its power output. Red lights are to warn you that you are operating outside of the amplifiers range.
Kicker ZX300.1... | Answered on Jan 26, 2013
This is a simple fix and happens quite offten the reason for the amp over heating is a weak ground this could be too small of cable or just bad ground bolt make sure wire is at least 10 gauge or bigger and ground bolt is clean metal no paint around ground post easy fix that will take the problem away good luck
Kicker ZX300.1... | Answered on Aug 22, 2011
open the amp up an see if u see anyhting burned on the inside next to ur fuse holder
Kicker ZX300.1... | Answered on Jun 22, 2011
  • For years Kicker has always been my favorite amp. For this amp I advise against bridging two speakers to it. This amp is intended to rune one speaker at no more than 2 Ohms total. If you bridge 2 speakers to this amp, you may burn the amp up or for sure send the amp into protect mode.
Regards, Tony
Kicker ZX300.1... | Answered on May 11, 2011
The fuse should be in line with the live power cable that goes from the amp to the car battery. You should be able to replace it by buying a new fuse that matches the blown fuse. You will take out the blown fuse (usually within 2 feet of the car battery) and replace it with the new one.
Kicker ZX300.1... | Answered on Mar 06, 2011
Faulty RCA cables, Or worse possible solution is if your amp stopped playing when it was pumping at high volume, you may have blown the RCA connectors inside your head unit Or inside your amp. If possible try another known good working amp with the wires you already have, If same happens, try different RCA cables. If problem persists after trying these, Its your head unit RCA connecters or amp RCA connectors. To rule out your amp connectors, try your amp in a friends car if possible, to rule out your head unit, try another good known working amp in your car with the wiring you already have
Kicker ZX300.1... | Answered on Mar 04, 2011
Hello charlietmn,
First off you need to turn your vehicle on, turn the stereo on. Go back and look at the amp. Do you see a power light on ? Is it green or red ?
If there is no light or a red light on, your amp is not getting power or is not grounded correctly in which you can try the following:
Check and make sure your ground cable is grounded properly. It should be attached to your vehicles frame on bare metal.
You can also check your fuses, in your amp, and in the power cable for the amp.
In my experience installing car audio, those are the two most common simple issues.
Post back after you've checked the things I mentioned. I will assist you further if you need further help. Thank you for choosing Fixya and have a great day.
-Daniel
Kicker ZX300.1... | Answered on Aug 10, 2010
what kind of subs u got
Kicker ZX300.1... | Answered on Jul 06, 2010
Check all the supplies, and make sure is properly grounded
Kicker ZX300.1... | Answered on Jun 13, 2010
try rerunning the wires and check them for cuts or burnt marks
Kicker ZX300.1... | Answered on May 14, 2010
first make sure the remote wire is good conected if it dont turn on then check the positive make sure it get the car metl good .
Kicker ZX300.1... | Answered on Mar 18, 2010
if you disconnect all the speaker wires then turn the amp on. if its still in protection its a internal problem in the amp and will require service or replacment
Kicker ZX300.1... | Answered on Feb 09, 2010
well... you have to wire the sub correctly to the amplifier to get good sound.. you could be giving it like an 8 ohm load and this will cause the amp to put out barely anything at all.. www.the12volt.com and the subwoofer wiring diagram willl tell you all you need to know...
Kicker ZX300.1... | Answered on Dec 13, 2009
Hello pruittdarryl,
Does the amp turn off when you remove the remote wire? If it does, then wire a toggle switch into the remote wire and just use it to turn the amp on and off. If the amp does not turn off with the remote wire removed, there is probably a short between the 12V+ and remote terminals. In that case, the amp is probably defective. If it is OK otherwise, you could still use it by putting a heavy duty toggle switch into the power wire itself.
Hope this helps.
Kicker ZX300.1... | Answered on Oct 11, 2009
You can buy splitters from radio shack or many other electronic/sound shops which split a male or female phono jack to separate stereo or mono output jacks. The most common is a phono jack to two separate mono 1/8" plugs. One way would be to purchase one of these, cut the ends off the outputs and strip the insulation, then use those to wire your amp. "Monster" brand puts out some of these splitters as well which use heavier gauge wire which would probably be most suitable for the task.
Kicker ZX300.1... | Answered on Feb 06, 2009
Kicker ZX300.1 Car Audio Amplifier Logo
23 questions posted
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Marvin
Marvin
Dalynn Turner
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kicker Car Audio & Video
Most Popular Question
kicker 300 1
  • Car Audio & Video
