Re: Why does my Samsung home theatre system HT-C550 come...
It's detecting a short, maybe in the speakers or a wiring issue. However even if you find the short it might be too late and has damaged the main power amp in the unit.
Sounds like it's stuck in it's power saving mode. If you've tried reset, checked all the connections, and kicked out the plug for a Cold Reboot and it's still no go, open the back, spit in it 3 times and hit it with a rock - or take it to a TECH because you've already done ALL that you are capable of, or you'd already know that.
Check your subwoofer function and level with Test Tones (page 29) and Auto Sound Calibration (page 30) and don't expect too much from an 8-lb 6.5" subwoofer and a multichannel amp that only draws 75 watts of electricity. Maybe place the sub nearer to a corner.
Register and download the manual for free audio.manualsonline.com
1. Go to the DVD input.
2. Select menu
3. Settings
4. Audio
5. ASC
6. Turn OFF the Auto Sound Calibration
7. Exit the menu
8. Go to the DVD input and retry the pro logic II button and switch to MATRIX.
(Also you have to enable the "matrix" setting each time on all of the inputs you use.)
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
