20 Most Recent Samsung HT-DM550 System Questions & Answers
manual
Switch on
Most likely, your unit has a condition known as DC Offset, meaning you have a bad amplifier. For more information, please visit my website at audioserviceclinic.com. Thank you.
12/5/2013 5:00:03 AM • Samsung HT-DM550... • Answered on Dec 05, 2013
0answers
0answers
My Samsung HT-DM550 shows "lock"
Be careful to do this with AC cable disconnected from AC outlet! If you have some experience with electronics, disconnect the wired plugs from power supply and discharge electrolitic capacitors to ground with a 330 ohm 1 watt resistor. Then reconnect the wired plugs. Be careful to do this with AC cable disconnected from AC outlet! Then connect to AC outlet and turn on the DVD player. You will see that DVD player restores to normal operation again.
[email protected]
11/4/2010 4:20:44 PM • Samsung HT-DM550... • Answered on Nov 04, 2010
2answers
Cutting out samsung ht-thx22
Start with checking your speaker wires, alot of times if you have positive & negitive crossing it will cause this issue
12/28/2009 4:04:29 PM • Samsung HT-DM550... • Answered on Dec 28, 2009
Cutting out
First check the speaker maybe one are on bad conditions and ready to burn,if they are fine the other cause be the audio amplifier IC
7/25/2009 4:14:27 PM • Samsung HT-DM550... • Answered on Jul 25, 2009
Disc Unknown keeps coming up on the screen
check the dust content on in the m,achine then check your settings to make sure its adjust accordingly
3/30/2009 8:27:52 PM • Samsung HT-DM550... • Answered on Mar 30, 2009
Problem when rading eny disks
This is a problem with the lens..
Get a lens cleaner CD with liquid and clean your DVD drive(just put two drops of liquid on CD and press play)
If this doesn't work you will need to replace the lens...The repair cost is not very high for replacing lens..
10/18/2007 11:57:34 PM • Samsung HT-DM550... • Answered on Oct 18, 2007
Why do my Samsung DVD Home Theater System HT-X50 shut off after about 20 to 30 minutes
Verify the timer function is set to OFF
7/13/2021 5:57:02 PM • Samsung Audio... • Answered on Jul 13, 2021
Samsung TV with audio no video
No displays on the TV screen with hearing the sound on your TV could be caused due to. A connection problems which is the main common issues. Or where there is a bad connection or faulty cables or not being hooked up correctly Or a problem with devices being connected to the TV
6/9/2021 6:59:44 AM • Samsung Audio... • Answered on Jun 09, 2021
2answers
I have a samsung HT-Z310 home theatre. I left plugged and when light was restored the power ic blew. So i replaced and the power came back on but immediately it comes on it say protect.
That's the power supply board isn't it. Have you checked the main power amp board? For when the power board failed it might have taken out the main power amp with it!
5/6/2021 4:34:54 PM • Samsung Audio... • Answered on May 06, 2021
What otg usb cable do i need in order to be able to run my new samson g track pro with a samsung galaxy a01. i have to be able to record on my phone.
sadly I have no idea what you need . being semi deaf I do not use my phone much
4/24/2021 12:32:20 PM • Samsung Audio... • Answered on Apr 24, 2021
Hi i got a samsung hdtv and want to connect the sound to my sansui avr 2000. Where do i plug my cables in and which cables can i use. Thank you
But it's an antique :>D It is before the time of HDMI connectors and may well be before the time of composite audio. You would be looking to Phono Connectors 'Out' on the television and a Phono Input Source on the AVR 2000. There is full specs and manuals here, but you have to register to get them. https://www.hifiengine.com/manual_library/sansui/2000.shtml ..
4/23/2021 6:00:53 PM • Samsung Audio... • Answered on Apr 23, 2021
Samsung HT-DM550 System Logo
Popular Tags
13 questions posted
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
cutting out samsung ht thx22
  • Audio Players & Recorders
