20 Most Recent Samsung DA-E750 Audio Dock Questions & Answers
manual
My saumsung DA-E750 is an ex display model and is stuck in 'demo mode' any ideas how i can reset this so i can get all features?
Small claims court or contact Samsung customer service to see if they can step you thru the process---usually it is holding certain buttons with unit on to exit the demo mode.
12/3/2012 4:31:46 PM • Samsung DA-E750... • Answered on Dec 03, 2012
How do I connect my Samsung soundbar to my seiki TV using Bluetooth
This will depend on how old the TV is and if it has bluetooth installed in it. Turn on the Surround Sound System, switch the system on and turn the bluetoothVisibility On. Go into the TV settings and find the bluetooth section. It will usually be it the 'network' section. Turn on the bluetooth and 'search for devices'. Connect to the sound bar when it appears. If yours does not have bluetooth you can buy a bluetooth sender/receiver that plugs directly into the TV to convert it for bluetooth.
8/9/2021 2:25:44 PM • Samsung Audio... • Answered on Aug 09, 2021
3answers
Have new Samsung 3D Blu Ray Home Theatre system
If you've find an answer to this, would you please post it here?
8/9/2021 1:18:41 PM • Samsung Audio... • Answered on Aug 09, 2021
Why do my Samsung DVD Home Theater System HT-X50 shut off after about 20 to 30 minutes
Verify the timer function is set to OFF
7/13/2021 5:57:02 PM • Samsung Audio... • Answered on Jul 13, 2021
Samsung TV with audio no video
No displays on the TV screen with hearing the sound on your TV could be caused due to. A connection problems which is the main common issues. Or where there is a bad connection or faulty cables or not being hooked up correctly Or a problem with devices being connected to the TV
6/9/2021 6:59:44 AM • Samsung Audio... • Answered on Jun 09, 2021
2answers
I have a samsung HT-Z310 home theatre. I left plugged and when light was restored the power ic blew. So i replaced and the power came back on but immediately it comes on it say protect.
That's the power supply board isn't it. Have you checked the main power amp board? For when the power board failed it might have taken out the main power amp with it!
5/6/2021 4:34:54 PM • Samsung Audio... • Answered on May 06, 2021
What otg usb cable do i need in order to be able to run my new samson g track pro with a samsung galaxy a01. i have to be able to record on my phone.
sadly I have no idea what you need . being semi deaf I do not use my phone much
4/24/2021 12:32:20 PM • Samsung Audio... • Answered on Apr 24, 2021
Hi i got a samsung hdtv and want to connect the sound to my sansui avr 2000. Where do i plug my cables in and which cables can i use. Thank you
But it's an antique :>D It is before the time of HDMI connectors and may well be before the time of composite audio. You would be looking to Phono Connectors 'Out' on the television and a Phono Input Source on the AVR 2000. There is full specs and manuals here, but you have to register to get them. https://www.hifiengine.com/manual_library/sansui/2000.shtml ..
4/23/2021 6:00:53 PM • Samsung Audio... • Answered on Apr 23, 2021
Can anyone tell me where I can get a manual for a Samsung AV-R730 Receiver
Contact Samsung directly to inquire.
4/15/2021 11:15:30 PM • Samsung Audio... • Answered on Apr 15, 2021
Samsung HT-C450 dvd with home theater, is prot mode. Please help me
This is usually caused by a damaged audio output stage. Time for a specialized repair.
2/26/2021 1:08:24 PM • Samsung Audio... • Answered on Feb 26, 2021
3answers
Can samsung HT-320 be upgraded to play m4v files
You know, m4v files have DRM protection and can't be played on Android devices. But you can do it with a 3rd party tool, NoteBurner. It can remove DRM legally and then convert m4v to mp4, mov, avi, etc. Besides, AC3 dolby 5.1 audio and multilingual subtitles can be all kept after conversion. You can learn more from: http://www.noteburner.com/mac-m4v-converter-plus.html
1/26/2021 10:49:41 AM • Samsung Audio... • Answered on Jan 26, 2021
Regent-HT-2004 To new Samsung but no sound comes out. Regent has only rca cables tv only has hdmi and optical. Have tried 3 different hook ups - rca to hdmi adapter with its own power source, hdmi to rca connection and now optical to converter to rca with its own power cord. I’m so frustrated because my ht-2004 sounds so much better than the tv speaker.
You probably will get the best result if you use a digital to analog audio converter. Amazon has a number of models: https://www.amazon.com/DA-Converters/b?ie=UTF8&node=3224445011 . You will need to provide the optical audio cable. You connect the TV's optical audio out to the converter's input. Then use the converter's RCA output to the home theater system's audio input. The TVs HDMI port is only an HDMI input (possibly with Audio Return Channel). This isn't usually resolved by an HDMI-RCA Converter. This converter might have worked to split off the audio signal from a Blu-ray player with an HDMI cable to the converter and then another HDMI cable to the TV and the RCA audio going to the Home Theater system. I hope this helps. Cindy Wells
1/1/2021 11:29:54 PM • Samsung Audio... • Answered on Jan 01, 2021
Samsung home-theater model no# HT-E330K, power supply ICA 801, qa 801 completely burnt can't see the value of the IC and transistor. Pls help with the value of the resistor
IC801 is ICE2QS03 and Q801 is KF8N60F You must replace the components that caused the failure otherwise it will not work properly.
12/31/2020 11:35:08 AM • Samsung Audio... • Answered on Dec 31, 2020
Part is missing pls help me what part number of this transistor this is from samsung home theater HT-330K thanks in advance
Service Manual. Page 5.2
SAMSUNG HT-E330K Service Manual download, schematics ...
elektrotanya.com > download
Translate this page Download SAMSUNG HT-E330K service manual & repair info for electronics experts.
Home Entertainment System HT-E330K ' Samsung Support ...
www.samsung.com > ... > Standard home cinema system
Mar 18, 2020 - Home Entertainment System HT-E330K. Solutions & Tips, Download Manual, Contact Us. Samsung Support Singapore. Missing: schematic ‎' Must include: schematic
12/21/2020 5:45:09 AM • Samsung Audio... • Answered on Dec 21, 2020
I have a samsung giga sound system Hs7000 and the subwoofers is working could they be blowed
You have to check the ratings of woofers for wattage they have been designed. Have you got a manual? They would definitely be working up to that mark.
8/16/2020 12:49:37 AM • Samsung Audio... • Answered on Aug 16, 2020
Samsung DA-E750 Audio Dock Logo
1 questions posted
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
saumsung da e750 ex display model stuck
  • Audio Players & Recorders
