Garden Logo
Rich Less Posted on Jun 06, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cub 1320. Why doesn't it crank?
New solenoid. Will turn over when terminals shorted
john h
Level 3:
Top Expert:
  • Garden Master 29,494 Answers
  • Posted on Jun 07, 2021
john h
Garden Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561237
Points
193449
Starter switch -seat safety -fuel problem
CJ Rock
Level 3:
  • Garden Master 4,429 Answers
CJ Rock
Garden Master
Level 3:
Answers
4429
Questions
0
Helped
1645527
Points
15024
Cub Cadet1320 starter solenoid energized requires the following;
BRAKE - ON (speed control lever to neutral).
PTO - OFF
IGNITION SWITCH - START
Ignition switch B terminal voltage must measure near same as battery positive voltage.
Link to wiring diagram.
https://weingartz.com/assembly-diagram/cub-cadet-parts-lookup/model-1320-s-n-147-008-207-400-130-232-100-131-232f100-139-232-100-electrical-system-1990-l-t-s-n-170-601-up/4285-233-164222
Link to owners manual.
https://www.manualslib.com/manual/33925/Cub-Cadet-1315.html?page=9#manual
ADMIN Andrew
Level 3:
Top Expert:
  • Garden Master 66,980 Answers
  • Posted on Jun 06, 2021
ADMIN Andrew
Garden Master
Level 3:
Top Expert:
Answers
66980
Questions
Helped
5090233
Points
379943
3 Related Answers
Anonymous
  • 109 Answers
  • Posted on May 03, 2009
SOURCE: cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
Andrew White
  • 2239 Answers
  • Posted on Mar 07, 2012
SOURCE: Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Anonymous
  • Posted on May 29, 2012
SOURCE: 1320 cub engine starts to die when going in revers
is your blades spinning when you try to go into reverse?
5answers
Cub cadet LTX 1045 Has no electrical power
Hi Charles.
this is all i can find on the net.
Start at the red (+) battery post and follow the battery cable to the starter solenoid. On the same top post of the solenoid where the battery is hooked there is another smaller red wire. Follow this small red wire and it will lead you directly to the fuse.
A Cub Cadet lawn mower won't turn over when it isn't getting power to the starter motor to spin the engine. This can be due to a bad battery; loose or corroded wiring; corroded terminals; bad ignition key switch; faulty safety switch; blown fuse; bad starter solenoid; or faulty starter motor.
7 Reasons Your Cub Cadet Lawn Mower Won't Turn Over or Crank You have finally found time in your busy schedule to mow your lawn. You're happy to be able to get it done and out of the way. However, this time your mower won't turn over. I have put together a list of items to check when you run into this problem.
Make sure you are following all safety precautions as shown in your owner's manual. If you are uncomfortable working on your Cub Cadet's starting system, contact your local Cub Cadet dealer or a knowledgable mechanic.
Dead or Bad Battery in Your Cub Cadet
A dead battery won't provide the power you need to turn over your Cub Cadet. Keep your battery charged, especially during storage, to extend your battery's life. Test your battery using the steps in the article "5 Things That Are Draining the Life of Your Lawn Mower Battery".
Charging a Battery: Use a battery charger to charge your 12-volt battery. Before you continue, wear protective gear to protect your eyes and skin from electrical shock. Follow these steps to charge your lawn mower battery with a charger:
  • Access the battery and terminals. You may need to use a screwdriver to uncover the battery. Do not remove the battery from the casing.
  • Connect the charging cables beginning with the positive cable first. This is the red cable or the one with the plus sign. Place the cable on the positive battery terminal.
  • Attach the negative cable to the negative battery terminal. This is the black cable or the one with the negative sign.
  • Do not touch anything that doesn't have a rubber coating to prevent electrocution.
  • Set the charger's voltage and amperage level to the desired level. The average volt level for lawn mower batteries is usually 12 volts. More amperage charges the battery faster. Start with two camps and work up to no more than 10 amps. A slow charge is best.
If the battery fails to hold a charge it must be replaced with a new battery. You can purchase a new battery at your location lawn mower dealership, hardware store or automotive store. Bring your old battery with you. Most places will charge you a core fee unless you provide them with your old battery.
Loose or Wires and Connections in Your Cub Cadet
Wires and connections can become loose with the constant vibration of your Cub Cadet. Make sure they are secure. While checking the connections and verifying the continuity is good, make sure the terminals are free of corrosion.
The outdoor elements can cause moisture around the connections causing corrosions. Try to remove this corrosion using a wire brush and a baking sold solution (2 cups water to 3 heaping tablespoons of baking soda). Replace the terminals if the corrosion is too severe.
Bad Fuse on Your Cub Cadet Lawn Mower
A fuse is installed to protect your Cub Cadet's electrical system. Check your mower to make sure you don't have a blown fuse. If you're unsure if the fuse is blown, you can check it by placing a multimeter probe on each prong of the fuse to measure resistance.
A resistance reading near 0 means your fuse is good. An infinity resistance reading indicates a bad fuse.
Replace a blown fuse with a fuse with the same amperage of the fuse you are replacing. If you continue to blow fuses, you should bring your Cub Cadet to your lawn mower dealership or lawn mower repair shop to troubleshoot the root cause.
Bad Ignition Switch on Your Cub Cadet Lawn Mower
The ignition key switch can be the culprit if you insert the key and turn it to find nothing happens. Your Cub Cadet will fail to turn over and start.
Check the switch using a multimeter to check continuity to determine if the ignition switch is the problem. To do this, look for the prongs mark B for Battery and S for Starter Solenoid.
Insert the key and turn it to the start position. With the multimeter set to measure resistance, touch one probe to the B prong and the other probe to the S prong.
A good ignition key switch will measure resistance near 0 ohms. A bad ignition key switch will measure infinite resistance and will need to be replaced.
Bad Safety Switch on Your Cub Cadet Lawn Mower
Your Cub Cadet has an operator presence control system installed to keep you safe. A safety switch can be defective and cause your Cub Cadet to fail to turn over.
Test your switch using a multimeter. You can also temporarily bypass the safety switch to identify a bad switch, but only do this for troubleshooting purposes.
Never operate a mower without the safety switch. Never run a mower when a safety switch is bypassed. A safety switch can save you from serious injury and you never know when you're going to need it.
Bad Starter Solenoid in Your Cub Cadet Lawn Mower
A starter solenoid is an electromagnetic switch that, when engaged, initiates the starter motor to turn over your Cub Cadet's engine.
The starter solenoid can go bad when the spring becomes weak or the copper plate begins to corrode. A weak starter, bad battery or bad ground can also cause the solenoid to fail.
Before you test your starter solenoid, you must have a fully charged battery. Continue testing the solenoid by using the steps to diagnose a bad starter solenoid in "How to Tell Your Lawn Mower Solenoid is Bad".
Bad Starter Motor on Your Cub Cadet Lawn Mower
Once you have ruled out the battery, cables, wiring, ground and starter solenoid as being the reason for your Cub Cadet won't turn over, it's time to look at the starter. The starter can be removed and tested.
I recommend having your local repair shop that specializes in starter and alternator repairs test your starter and rebuild it if possible before just throwing a pricey new starter at your Cub Cadet mower.
Still Having Problems with Your Cub Cadet Mower? If the above list did not resolve your problems, I put together a guide of common mower problems and solutions. You will find links to more in depth articles for each of these common issues. You can find the article at "Common Cub Cadet Lawn Mower Problems".
If none of this helps you out i dont know what you are going to do.
Can I replace a 2 terminal solenoid with a 1 terminal ? If so how?
The diagram for the LT1045 shows it has a single control terminal solenoid. If you want to use a two control terminal solenoid, simply jumper one of the two terminals to the solenoid frame (mower chassis). The other terminal goes to the start circuit (Org/Wht).
If the machine has a two terminal solenoid then it's not a factory configuration. If your replacing a two terminal with a one terminal, connect the start circuit (Org/Wht) to the singe control terminal. The opposite side of the coil is bonded internally to the solenoid frame (mower chassis).
The contactor side of the solenoid does not change. One contact connects to the starter motor and the other contact connects to battery positive and a smaller gauge power feed.
2answers
2009 Cub 2550. Why does solenoid wire have constant 12 volts?
Guessing, the switch is incorrectly wired. Should have power going into it, Key position 1 puts power into the ignition system, position 2 connects the starter solenoid. Letting go of the key, takes it back to run and disconnects power to the solenoid.
Jul 19, 2021 • Garden
Won't turn over
you probably have a bad starter solenoid. You can check it by jumping across the two terminals. If it cranks over then it is bad, if it doesn't then you have another problem and need to check the battery cable connections and/or starter, but I would look at the solenoid first
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
2answers
2answers
Have same problem, turn key and does not crank
it is very possible that your battery cables are corroded or too small - this is a common problem with MTD machines, they cut costs by using cables that are marginal at best. i suggest replacing the battery cables, then you know that you're getting full battery power to the starting system. then you can check other things if that doesn't solve it. first rotate the engine by hand, sometimes the starter gear gets stuck in the flywheel. check the solenoid, pull the white [or yellow] wire from the solenoid, run a jumper wire from that terminal to the big terminal with the battery cable attached to it, it should crank the engine. if it doesn't crank, replace the solenoid. sometimes, there's a relay in the wiring harness that fails, but rare
2helpful
2answers
CUB CADET LT 1046 WONT CRANK
If the head lights come on, check the PTO switch connector. Very often the connector comes loose.
If no headlights, check the fuse. If blowen look for shorted wiring: Mice may have chewed wires inside the flywheel cover; check the head light cable. Often it rubs through at the hood pivot; check the lead on the carburetor solenoid, sometimes they rub through at the wire ties holding the red lead to the solenoid.
I am a certified Cub service tech,and those are the common problems I have run into.
Oh, one more thing, make sure the battery is good. Load test it or have it load tested if you don't have a tester. Don't just check it with a volt meter. That wont load the battery to check for dead cells.
1helpful
Cub cadet 1024 wont turn over
May 02, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
