Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Need wiring DIAGRAM FOR CUB CADET HDS2135 Ser. No. 381394. Problem starting solenoid does not engage starter every time key is turned. If I jumper from hot batt. lead to terminal on solenoid, works every time. Voltage on starter terminal at soleboid is 12.0. Batt. voltage is 12.5.
Posted by Alexander Jackson on
5 Related Answers
joboo1
Jim London
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
Anonymous
  • 109 Answers
SOURCE: Cub Cadet tractor failure to move
Check the bypass for the transmission, make sure it is in all the way, if it is, check the belt from the engine to the transmission, make sure the belt tension spring is riding on the belt and that the belt is tight.
Posted on Apr 16, 2009
dieseldriver
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
Anonymous
  • 62 Answers
SOURCE: cub cadet 2166 won't start. replaced switch.
SOUND LIKE A LOW VOLTAGE PROBLEM. MAKE SURE YOUR BATTERY IS GOOD
Posted on Sep 25, 2009
Anonymous
SOURCE: Have same problem, turn key and does not crank
Take the PTO switch apart and clean the contacts.
Glue the bottom cap back on and give it a try.
There are contacts inside that will cut all power to the starter from the ignition switch.
It worked for me.
Posted on Sep 27, 2009
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
I have a cub cadet tank with a Honda motor need wire diagram for starting system solenoid clicks wont turn motor over only have power to solenoid some times
That sounds like the starter switch itself is bad. The starter switches on riding mowers are just cast pot metal and if they get moisture inside of them and wear and tear, they will act like that!!
Sep 22, 2014 | Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Jul 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet zero turn will not start with the key
basically you fixed it youself
if your solenoid is engageing and your wiring is clean and tight from the battery positive to one side of the solenoid and from the other side of the solenoid to the starter?
then you need to replace your solenoid.
Jul 06, 2009 | Mtd Garden
Cub cadet 1024 wont turn over
try taking an insulated screw driver and jumping across both terminals on the solenoid, if the engine turns over, the solenoid is bad and will need to be replaced
May 02, 2009 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
1,312 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
