Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
Posted by Beth on
Andrew White
  • Cub Cadet Master
  • 2,239 Answers
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Posted on Mar 07, 2012
Tim Garnett
    New Friend:
  • 4 Answers
With my LT1024 I had the same symptoms. Turns out, approx every 40 hours or so the valves need to be adjusted. This fixed my problem.
Posted on Apr 01, 2012
5 Related Answers
Rexter1
  • 40 Answers
SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Posted on Mar 12, 2009
Anonymous
  • 173 Answers
SOURCE: My Cub Cadet model 1525 rider won't start. I turn
You could have a seat safety switch bad. Bounce up and down on the set to work the safety switch often.
Posted on Jul 08, 2009
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: belt installation for a cub cadet lawn mower
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10051
Posted on May 20, 2009
Anonymous
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
Anonymous
  • 8 Answers
SOURCE: cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Posted on Aug 16, 2009
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
I have a 2006 cub cadet LT1050 lawn tractor with a Kohler SV720 engine. It will not turn over, I put a 200 amp jump on starter barely turns over, took plugs out turns over good. thought maybe exhaust valve...
Check oil level. If needle/float in carb stick gas can trickle down into crankcase and cause a condition like you listed. I would also check valve lash. If all these are good, check all grounds and connections, grounds, starter, solenoid. Clean all contacts with wire brush or emery cloth, could be electrical. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 12, 2013 | Cub Cadet Garden
Won't turn over
you probably have a bad starter solenoid. You can check it by jumping across the two terminals. If it cranks over then it is bad, if it doesn't then you have another problem and need to check the battery cable connections and/or starter, but I would look at the solenoid first
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 15, 2013 | Cub Cadet Garden
Cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Jun 09, 2012 | Cub Cadet Garden
Battery drained after use
A lot of automotive parts stores will check a battery for free...
find your lowest amp rated (less than 10) and charge it over night.
Have battery load tested.
if good, place ammeter between battery and the rest of the tractor to check and see if load from running engine is draining or alternator isn't working.
or fast way to check an alternator on almost anything, start with battery, the pull off the negative (black) cable, if engine dies nothing is powering the engine but the battery (on an alternator driven electrical system, the battery is only used to start the engine)
May 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet ZTR will not start
Is the blade engagement off? If that is ok, does the solenoid even click when you put the key to start position? If the solenoid doesn't even click check the battery connections and make sure they are good and clean. If the connections are good, are you sure the new battery is fully charged. If the battery sat around for a long time in the store it could need charged. If all that is good and then you don't get the starter solenoid to click when you put the key in start position, then it is either the seat switch, parking brake switch, handle switches, or mower engage switch keeping it from starting. If all that is ok maybe you have a bad starter solenoid. Please rate my answer so I am rewarded points for it.
Jan 30, 2012 | Cub Cadet Garden
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a Cub Cadet 2166 . When I try to start it, the starter drive throws up, but won't turn the engine. I took the starter off and when you turn the key to start, the drive throws up and turns slow...
Can you measure the voltage of the battery? If you are getting low voltage then the battery needs to be charged or replaced, if the voltage is good then you probably have a bad starter. It might be something you can see like shorted windings on the motor.
Jun 07, 2011 | Cub Cadet Street Sign- tractor lawn riding...
STARTER WONT TURN ENGINE SOLENOID CLICKS BATTERY IS FULLY CHARGED
Do you have 12volts dc to your starter when your solenoid clicks?
if not replace solenoid,if yes check starter next and then be sure engine is not siezed?
Apr 30, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
4,302 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
