Based on the information you provided, it seems like the Kenwood TK-2000 radios you have may have been programmed with the wrong band split. The TK-2000 is available in both VHF and UHF frequency ranges, and it's possible that the radios you have are actually UHF models, despite being listed as VHF frequencies when you read the radios.
To check if your radios are UHF or VHF, look for a label on the back of the radio that specifies the frequency range. If it says UHF, then the radios can only accept frequencies in the 400-440 MHz range. If it says VHF, then the radios should be able to accept frequencies in the VHF frequency range.
If you've confirmed that the radios are indeed VHF models, then it's possible that the band split settings may need to be adjusted in the programming software to match the specific VHF frequencies you're trying to program. I recommend checking the manual for your programming software to ensure that you have selected the correct band split settings before programming the radios. If you're still having issues, it may be helpful to contact Kenwood customer support for further assistance.
Maybe your graphics card built inside the computer is operating at it's max. But if you are seeing a split screen, you either have a lcd screen problem or a video problem. Have you tried plugging an external monitor into the laptop to see if it gets the split screen?
CHECK SWR's, and check for loose coax connectors and try a different microphone. new stock mic's $6.99 max price here in temple, TX, and rk56 noise cancelling mics$38.99 Max here too Temple, TX.
Suggestions:
(best to worst)
1. Use a "Y" USB cable with that drive.
2. Use a shorter USB cable.
3. Use the new cables with the canon
4. Use a 2.0 hub
The drive should have come with a "split" USB cable (USB "Y" cable). The drive requires a "data" and a "power" connection to your computer.
Get one at Radio Shack, Best Buy, Office Depot/Max... ($10)... or Dollar store ($1.09)
Very loud it never gonna be. It's a tv with very small speakers, but I have a lot of customers who complain about that and I checked first the signal source. Sometimes the sattelite receiver or cable box give a sound not so good. The best way to check it is to plug something (an antenna or just a 2 inch wire) in the coaxial plug to see if on the tuner is the same sound. I bet is gonna be stronger.
