20 Most Recent JBL Flip Wireless Bluetooth Speaker Black Questions & Answers
JBL Flip driver for Windows 7
You probably need to update the driver for the bluetooth in the laptop to support latest bluetooth proflies. Check following link for a how to.. http://windows.microsoft.com/en-us/windows/update-driver-hardware-isnt-working-properly#
6/27/2019 2:52:09 PM • JBL Flip... • Answered on Jun 27, 2019
How long douse jbl need to charge before using? bluetooth speaker?
You will need to charge the JBL Flip speaker for 3 hours before using it. You can check it on the manual in the below link: http://demandware.edgesuite.net/aauj_prd/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw99da2e5e/pdfs/FLIP_OM_EN.pdf
7/10/2016 7:20:50 AM • JBL Flip... • Answered on Jul 10, 2016
0answers
Why does it turn off after 10 minutes of use?
maybe u havent charged its internal battery for long enough..
5/19/2015 3:47:37 PM • JBL Flip... • Answered on May 19, 2015
My jbl flip will not connect. it say its paired to my pc but it will not connect. i have tried disconnecting the device but it will not let me . help
does ur speaker have a default passcode that needs entering. mine did many defaults are 0000...
5/19/2015 3:46:36 PM • JBL Flip... • Answered on May 19, 2015
0answers
Jbl flip no sound
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
7/2/2014 4:46:23 AM • JBL Flip... • Answered on Jul 02, 2014
0answers
No sound JBL
Be the first to answer 1/18/2014 3:18:32 AM • JBL Flip... • Posted on Jan 18, 2014Be the first to answer
0answers
How i get a pass code for pairing Bluetooth on my PLYE HYBRID AMPLIFIER P2002ABTI
To obtain the passcode for pairing Bluetooth on your Pyle Hybrid Amplifier P2002ABTI, you will need to refer to the user manual or documentation that came with the amplifier. The passcode or PIN for Bluetooth pairing is typically specified in the manual, as it can vary depending on the manufacturer or model. If you don't have access to the manual or cannot locate the passcode information, you can try some common default passcodes such as "0000" or "1234," as these are often used as default codes for Bluetooth devices. However, it's important to note that these default passcodes might not work for your specific amplifier model. If none of the above options work, I recommend reaching out to Pyle's customer support directly. They should be able to provide you with the correct passcode or guide you through the pairing process for your Pyle Hybrid Amplifier P2002ABTI.
5/18/2023 2:27:20 PM • Radio... • Answered on May 18, 2023
2answers
Astatic D104
5/7/2023 9:31:43 PM • Radio... • Answered on May 07, 2023
My iLive IBB313 bluetooth boombox won't charge
First off I have had one of these for almost a decade now...a very reliable item. Most likely the Lithium Ion battery is shot. By removing all the screws in the deep holes on the back, and two tiny ones in the handle you can open the device up. The battery is soldered in but is easily removed with wire snips, On Amazon look for 18650 replacement battery and either solder to appropriate ends or get "18650 battery holder (what I did) you ll likely get a lot more years out of the device
4/30/2023 5:00:00 PM • Radio... • Answered on Apr 30, 2023
JBL Flip Wireless Bluetooth Speaker Black Logo
31 questions posted
Top JBL Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a JBL Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • JBL Radio Communications
Most Popular Question
long douse jbl need charge before using
  • Radio Communications
