20 Most Recent Sharp Aquos LC-32GD4U 32 in. LCD HDTV Questions & Answers
This is a sign that the power board has failed, If you post the model number, we can find out about parts.
Sharp Aquos... • Answered on Apr 14, 2017
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Sharp Aquos... • Answered on Dec 31, 2014
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
Sharp Aquos... • Answered on Sep 24, 2014
Sharp AQUOS LC 22SV2E Operation Manual Try this link to download its user manual. Its specification page will give you all details about its performance. Gopakumar Gopalan Google
Sharp Aquos... • Answered on May 23, 2014
While tv is off press and hold buttons on tv VOL(-), A/V and switch it on, release buttons after 5sec. Suppose to get back to normal state then. I checked on my old sharp lcd lc-32ra1e and worked.
Sharp Aquos... • Answered on Jun 20, 2013
press tv,press setup until 2 blinks,enter 994,press setup briefly,enter049,press the button you want to put the sleep timer on or off
Sharp Aquos... • Answered on Apr 14, 2013
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Sharp Aquos... • Answered on Apr 17, 2012
unplug the tv and press and hold vol_ and input from tv and plug in tv will go to servive menu then select initil function and press ok tv will go to green screen unplug the tv and plug back in after five seconds . k will be removed
Sharp Aquos... • Answered on Mar 06, 2012
my sharp aquos flat screen has a low volume, even when turned up to max. how can i increase the volume
Sharp Aquos... • Answered on May 31, 2011
Are you running it in Demo mode in menu
hope this helps
Sharp Aquos... • Answered on Feb 22, 2011
U can tries take out the batteries,pushes all the buttons a couples times,wait awhile put batteries back,see if that solved ur problems.Not the remote is garbage now.Remote control have dead CPU chip or it CPU is short will have some functions lelf,remotes devices are heavily depend on it CPU chip.This can't be repair,because it just a circuit board and a CPU chip about it on the remote control,that it.Try website like Remotes.com to buy an original remote or very close to it.
Sharp Aquos... • Answered on Jan 22, 2011
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Sharp Aquos... • Answered on Jan 19, 2011
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
Sharp Aquos... • Answered on Dec 15, 2010
The television needs a main board and or a panel. This will probably be too expensive to repair. You can see if Sharp will make and exception for you and let you send digital pictures of the problem in.
Sharp Aquos... • Answered on Dec 09, 2010
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
82 questions posted
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
folks r nive got sharp lc 26sa1e sound
  • Televison & Video
