I have a Bissell little green machine, model 1400, and I need to clean the suction head but I cannot figure out how to remove the clear plastic cover. There are hairs and carpet fibers stuck there.
If your Bissell Little Green Machine has no suction at the hose end but good suction underneath the dirty water tank, try these steps: check for clogs in the hose and attachment, ensure the tank and filters are properly seated, test without an attachment, inspect for damaged hoses or seals, clean the machine, and run hot water through the hose. If the issue persists, contact Bissell customer support for assistance or consult your user manual for specific troubleshooting steps.
On some of those, the clear cover snaps off. If it wont, then use a pipe cleaner to reach those spots after you let it soak for a while in warm soapy water.
If you go to this URL:
http://www.vacpartswarehouse.com/Bissell-Little-Green-Models-1400-2-1400-5-1400-H-1400-U-s/591.htm
you will see an exploded view of your unit and see the switch and associated part number.
If you find this solution helpful, I would appreciate a Thumbs Up from you.
Thank you!
Paul
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Like everyone else (!) your lint filter is probably clogged. It is located on the top clear palstic section (the one with the dial to switch from tool to floor use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Flip the door open and you will probably find it is clogged with hair, carpet fibre., etc.. Clean it out and you should have suction again.
