If the machine only is leaking while the water tank is attached, but is correctly inserted, then the intake line could be broken or disconnected. This will require a repair. If leaking only occurs while the machine's pump is activated then the drain area of the machine might be blocked
Hi, Its got a blockage. Try removing and cleaning the brew unit, but I can tell you now, it needs to be looked at by a repairer. A normal blockage should leek in to the drain tray, but a leak on the bench means something is split or cracked. I do repairs. Dazza
If it is coffee colored water, check the chamber under the white plastic valve behind the brew unit, that might be blocked with coffee grounds. If it is clean water one of the lines might need new o-rings.
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk
Albany, NY
