The same thing all top row lights blinking happened. Unplug unit, pull the brew unit out and snap back. Plug in and prime. Should reset fine.
Hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
SOURCE: GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
SOURCE: Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
SOURCE: i have gaggia brera and after brewing a cup the
Try to descale your machine, use descaling tablets or descaling powder.
SOURCE: Hi, we have received our Gaggia Brera today and it
Hello, are you turning to the selection knob back to its central position? once you do this the and the unit warms up the triangle should disappear The icons displayed blink slowly to show that the machine is warming up. When warm-up is complete, the machine performs a rinse cycle of the internal circuits. During this phase, the icons displayed • When the operations described above are completed, the icons on the display will illuminate. The display will appear as shown to the side. The displayed aroma is the factory setting when the machine is switch on for the fi rst time, or it is the same as the aroma that was selected for the last brewed coff ee. The machine is then ready to brew
will blink in sequence.
beverages if you have any further questions or the triangle does not go away please message me back for further diagnosis Thank you
Rick
SOURCE: gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
up.
will illuminate.
brewed coff ee.
Rick
