20 Most Recent Gaggia 102534 Espresso-Color Semi-Automatic Red Espresso Machine Questions & Answers
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Gaggia 102534... | Answered on Jan 06, 2014
HI JULIE,....MAKE SURE YOU ARE NOT FILLING THE WATER DISPENSER PAST IT'S OVER-FLOW...THERE IS A HOLE TOWARDS THE TOP...YOU DO NOT WANT TO FILL PAST.
HOPE THIS HELPS!
Gaggia 102534... | Answered on Sep 03, 2011
The problem is one of the most frequent. A scale deposit have moved in the coffee solenoid valve and it blocking the internal mechanical part of the valve to seal closed. This is one of the main reasons you should perform a descale as frequent according the hardness of your water. Moreover the first solution is to perform a descaling now and you can be lucky that the valve will be clean and close seal again. You should flush most of the descale solution by pressing the coffee button so the coffee valve work more. In other case if the problem remain you can perform a second descale the next day and if again you don't have results then you will need to disassemble the machine remove the valve and clean it manually. Please not that the coffee valve can be blocked in the same way not from scale but from coffee grease from long time use and the descaling will also help to solve the problem as describe above.
If it is not heating then the thermostats need to be reset. If it is not brewing coffee but you can hear the pump going or you can get hot water then the shower screen needs to be cleaned or the machine needs to be descaled.
Gaggia 102534... | Answered on Aug 04, 2011
If it sprays from around the filter spouts when making coffee then either the gasket up there is dirty or damaged.
Gaggia 102534... | Answered on Jun 29, 2011
Your are propably need to prime the machine. This mean that air blocked in the machine and need to get out and fill all pipe system with water.
To do this you need to warm up the machine and turn the hot water knob so you will get one cup of hot water from the steam wand. After that try to get some water from the coffee head without any coffee in the filter handle. Now the machine is ready for coffee again. You will need to prime the machine very often so try to remember the procedure. This will happen again usually after you use the steam process and this normal for your machine.
http://www.fixya.com/support/r5772014-saeco_gaggia_spidem_ventilate_prime
Gaggia 102534... | Answered on May 01, 2011
Turn it off, you don't want it to run empty and it takes hardly any time to heat up.
Gaggia 102534... | Answered on Jan 20, 2011
Try to remove the spare parts of it and clean the blades of it. I suggest to clean all the angles of the espresso machine especially on the mixer part. Then restart the machine and check if the ground coffee will grind. Otherwise call the manufacturer and replace the blades of it...
Gaggia 102534... | Answered on Dec 27, 2010
Try descaling the machine, there might be some mineral buildup preventing the machinefrom working.
Gaggia 102534... | Answered on Apr 15, 2010
Remove the filter and the 2 allen wrench screws that hold the diffuser in place, then carefully remove the spring and valve seat which is probably not in there as they should be, make sure they are seated correctly and re assembly machine. At some thine there was a massive surge of pressure and that moved the valve seat out of place.
Check the end of the nozzle it might be blocked use a paperclip to clear.
Go onto this site and search for gaggia parts and you should get the seal you require.
www.1st-line.com/machines/home_mod/gaggia/index.htm
Regards
Alan Hood
ami-man
Uk
Gaggia 102534... | Answered on Apr 06, 2010
Gaggia 102534 Espresso-Color Semi-Automatic Red Espresso Machine Logo
29 questions posted
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Gaggia Coffee Makers & Espresso...
  • Gaggia Coffee Makers & Espresso...
Most Popular Question
just stopped working
  • Coffee Makers & Espresso Machines
