20 Most Recent Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Questions & Answers
the most likely reason for poor flow through the brewhead is a blockage in the outlet valve.the outlet valve is behind the shower disc holding plate and can be removed with 13mm socket. a straightened paper clip needs to be insrted in the outlet to clear any internal blockage,then pump water through. if the outlet valve splits in two ensure the rubber bung is inserted upwards.once refitted all should be fine
Gaggia Coffe... | Answered on Feb 05, 2019
I would suspect rough handling of your suitcase, leading to some loose or broken connections inside. I recommend opening it up and looking for obvious disconnections. If you don't see any, the next step will be to use a tool like an electrical continuity tester (which can also test for a blown fuse). There is a lot of information about Gaggia Classic repair online -- just search for "Gaggia Classic repair".
Gaggia Coffe... | Answered on Sep 27, 2013
Remove the 2 allen wrench screws under the screw and screen, this will drop the diffuser, careful do not loose spring and plastic ball that is in there. Then run machine without parts in place to check if water goes through. If yes replace parts minus screen and screw and test, it taht works insert screen and screw and test.
Gaggia Coffe... | Answered on Oct 06, 2011
Remove the top panel and check the thermostats.
Gaggia Coffe... | Answered on Aug 15, 2011
First thing I would check is the end of the steam wand to make sure it is not blocked. Then if you are getting hot water for making espresso, I would remove the top cover and check the topmost thermostat.
Gaggia Coffe... | Answered on Apr 22, 2011
Contact Us SHRIRO AUSTRALIA PTY LIMITED
A.C.N. 002 386 129
23-27 Chaplin Drive
Lane Cove
NSW 2066
Australia
Hotline: 1300 768 112
Phone: +61 (02) 9415 5000
Fax: +61 (02) 9415 5001
Email: [email protected]
Gaggia Coffe... | Answered on Apr 09, 2011
Water is supposed to flow through the four holes then to the screen, then the coffee, so if you are not getting any flow through the screen then either the holes in the diffuser are blocked or the screen is dirty.
Gaggia Coffe... | Answered on Mar 14, 2011
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
69 questions posted
Top Gaggia Coffee Makers & Espresso Machines Experts
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Gaggia Coffee Makers & Espresso...
  • Gaggia Coffee Makers & Espresso...
Most Popular Question
gaggia classic turn no light power
  • Coffee Makers & Espresso Machines
