SOURCE: Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal
occurs due to belt slippage. I would check your belts (look for cracks.
Check the belt tension as well, most washers have an adjustment,
normally on the motor that allows you to increase the tension of the
belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
SOURCE: Hotpoint Electric Dryer Model NBXR453EVOWW squealing when turned
Replace the drum support bearing at the rear of the drum.
SOURCE: Dryer makes a loud squealing when first started
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Testimonial: "Removed the drum and oiled the various rollers Quieted the noise. Sounds like a new one again. Thanks "
SOURCE: washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Manually turn the motor and drum and listen for the
noise, if so the motor bearings, the drum agitator shaft and fittings must be
checked. Also the suspensions which include the shock absorbers and springs,
the body clamps must be checked to be in correct alignment and not changed in
position. Tightening of the mounting is
also very important. Finally in most cases a drop of OIL or smear of grease on
the moving parts cane solve most issues.
Check this link :
