LG LHB953 Theater System Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't get the sound to bypass the tv's speakers to my network blu-ray home theater system.
Fla-Hosting.net
Level 2:
Scholar:
  • Expert 77 Answers
  • Posted on Sep 19, 2009
Fla-Hosting.net
Expert
Level 2:
Scholar:
Answers
77
Questions
0
Helped
31272
Points
204
Are you hooking the TV to the Blu-Ray HTS with the HDMI cable¿ I have a client that had the HDMI cable from the HTS to the TV and needed to purchase an "Optical Cable" to get the sound from the TV to the HTS when they were using the cable box as the input. I hope this helps you going into the right direction.
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
User manual
You get surround sound only if you hook up your Optical out from your TV to the Optical IN on the HT-H4500 using an optical audio cable. You may have to buy such a cable if one was not included with the TV or the home theater.
Follow the link below and click on the Manual tab.
Samsung Home Theater System HT H4500 Home Audio
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
2helpful
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
4helpful
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
5helpful
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
1helpful
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
