Question about LG HX906SB 5.1ch 3D Bray and DVD Home Cinema System
Boot and please wait problem - LG HX906SB 5.1ch 3D Bray and DVD Home Cinema System
szlag
    New Friend:
I had the same issue twice (2 diffrent devices) on LG Blue-ray HX-906 - stuck on "please wait" after switching it on. It turned out to be defective mainboard - main BGA chip (the one with black radiator) has some problem with connection to mainboard. Here is how to repair it:
- dismount the mainboard
- take off the radiator from the main chip
- put alluminium foil around the chip to avoid unnecessary heating up of other parts of PCB
- heat up the chip using air hotgun to about 200 celsius for about 5 minutes.
Mount everything in reverse order and enjoy
Posted on Nov 17, 2018
  • Aimar
    Aimar Feb 05, 2021
    Hello. Just tried (5.02.2021) this heating and it really works. Most heating went under black "radiator" and just in case heated little everything. Just tried and no "please wait" anymore. THAKN YOU!
  • Aimar
    Aimar Feb 05, 2021
    My unit is LG HX906PA or HB609PA
Claude Kayser
    Top Expert:
  • LG Master
  • 9,098 Answers
LG HX906SB 5.1ch 3D Bray and DVD Home Repair ... - Fixya
www.fixya.com/.../p3079971-lg_hx906sb_5_1ch_3d_bray_dvd_home_...
Recent LG HX906SB 5.1ch 3D Bray and DVD Home Cinema System questions,problems ... Lg bluray boot ... My bluray home theatre stuck on please wait · LG ...
How do i reset my lg hx906pa cinema system - Fixya
www.fixya.com/support/t16589274-reset_lg_hx906pa_cinema_system
Feb 15, 2013 - Question about LG HX906SB 5.1ch 3D Bray and DVD Home ... I have read all the instructions but I have not found a solution to my problem. ... Lg hb44 home cinema comes on but will keep saying please wait ... Lg bluray boot.
Make LG BLU RAY 3D multi regional - Fixya
www.fixya.com/support/t14433338-make_lg_blu_ray_3d_multi_regional
Sep 23, 2012 - Question about LG HX906SB 5.1ch 3D Bray and DVD Home .... 3d blu ray home theather model# lhb336 problem/boot and please wait.
Posted on Jan 28, 2016
We found an inconsistency in your data and are fixing it. Please wait while we restart your computer
To enter safe mode, At boot start tapping F-8. Or, Unplug, while running, remove battery, plug in, reboot, a list should come up select safe mode with networking. OR, while running open MSCONFIG, by opening RUN and typing MSCONFIG and OK, select Boot Tab, Safe boot, restart. Try Running Command Prompt, as Administrator, type sfc /scannow.
Lg network 3d blu ray home theather model# lhb336 problem/boot and please wait
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Parts are available on our web
Won't boot up beyond the system password screen. I never set a password. This is an improvement from the black screen of death with only a cursor that I had earlier. PR: wait... I:...
use another pc go to a linex site download ubuntu live cd and you can boot your pc,linux MINT is very good also.there free.learn the commands and how to use the terminal and you can do anything.It will boot up your pc and you can go on net also.
The please wait then welcome and stays at welcome.
1. Try to boot your computer in Safe mode and run a full system virus scan with your anti-virus software, this may fix the problem. The system will boot in safe mode only if its not a major damage to the file. If the system is not booting in safe mode, then perform system restore. Click start>all programs>Accessories>System tools>System Restore. Restore computer to a date where it was working fine.
2. In case the system refuses to boot up at all, then it is recommended to run a repair setup of windows Xp. To run repair setup, boot the computer with Windows Xp bootable CD and on installation screen, press R for repair setup. For detailed steps see http://www.windowsreinstall.com/winxppro/installxpcdrepair/indexfullpage.htm
Boot error...please wait
1 Hold down the power button for 15 seconds.
2 plug into usb on pc.
3 Update the firmware
http://www.rcaaudiovideo.com/categories.aspx?product=317&post=4
Good luck. Worked great on mine.
3answers
Mother board driver issues
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
LG HX906SB 5.1ch 3D Bray and DVD Home Cinema System Logo
Top LG Audio Players & Recorders Experts
 Francisco Mauricio...
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
