20 Most Recent Samsung HTC5500 Theater System Questions & Answers
When unit is turned on, it displays a code of (PROT) and then shuts off.
the amplifier is bad and the main board will need to be replaced.
5/29/2015 3:41:33 PM • Samsung HTC5500... • Answered on May 29, 2015
0answers
0answers
0answers
Fanchk
Be the first to answer 2/2/2014 5:30:07 AM • Samsung HTC5500... • Posted on Feb 02, 2014Be the first to answer
0answers
0answers
HT-C5330
Be the first to answer 8/20/2012 6:12:48 PM • Samsung HTC5500... • Posted on Aug 20, 2012Be the first to answer
Wont read disk htc5500 bluray player
have you tried washing disc with small amt dish soap? Dry w/soft cloth NOT paper towel.
4/23/2012 1:08:23 AM • Samsung HTC5500... • Answered on Apr 23, 2012
Hi I have the htc5500
Is the center channel speaker working? Try it with test tones first.
http://www.retrevo.com/support/Samsung-HT-C5500-Home-Theater-Systems-manual/id/23668bh244/t/2/
8/1/2011 8:16:44 PM • Samsung HTC5500... • Answered on Aug 01, 2011
I cant get my remote
Please explain more about the problem?
Do you get a green light on the BD receiver/TV button?
7/17/2011 5:16:54 PM • Samsung HTC5500... • Answered on Jul 17, 2011
I have a samsung tv
Hi, When you connect the HDMI you do not need to connect RCA cable as well. Do not connect 3 all together. HDMI,RCA and DOC. Check manual for proper connections. You can damage your systems. Please read MANUAL.
6/9/2011 8:00:56 AM • Samsung HTC5500... • Answered on Jun 09, 2011
I Have a blueray home
Try setting your blu ray player to hdmi out before you unhook the av cables. Then try reconnecting rhe hdmi see if it helps.
4/22/2011 4:04:28 PM • Samsung HTC5500... • Answered on Apr 22, 2011
I have a samsung ht c 550 system. when I push the
What DOES it do or show - anywhere on the panel? Perhaps it's in protection.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
3/3/2011 4:35:12 PM • Samsung HTC5500... • Answered on Mar 03, 2011
How do I connect my
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
1/27/2011 4:58:07 PM • Samsung HTC5500... • Answered on Jan 27, 2011
No music. if just watching TV.
Please elaborate on the fault . If there is no sound from TV to your Music system then check the output connection cables , check for the signals in the output- of not TV must be checked or if there is no input in the music system the selector can be cross checked.
1/22/2011 11:36:37 AM • Samsung HTC5500... • Answered on Jan 22, 2011
My HTC5500 led buttons on
had the same thing - unplug the power for a few seconds and should fix it
1/7/2011 12:42:31 PM • Samsung HTC5500... • Answered on Jan 07, 2011
NO OPTICAL SOUND I connected HDMI from reciever
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
1/7/2011 6:23:35 AM • Samsung HTC5500... • Answered on Jan 07, 2011
Samsung HTC5500 Theater System Logo
40 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Audio Players & Recorders
Most Popular Question
htc5500
  • Audio Players & Recorders
