LG NB2420A 160W Sound Bar Logo
Question about LG NB2420A 160W Sound Bar
HOW CAN I MAKE A HARD RESET FOR AN LG SOUND BAR WITH CODE NB2420A
THE BLUTOOTH DOES NOT GET IN BLUTOOTH READY OPTION IT APEARS BT AND STAYS LIKE THAT I CONNECTED AN EXTERNAL DEVICE WITH AUXILIAR CABLE AND NO SOUND COMES OUT. IS LIKE SOMETHING IS BLOQUED
Posted by Felipe Saravia on
Senthil Kumaresan
    New Friend:
To do a hard reset for LG soundbar las450h or 550 series, long press the volume min button on the soundbar and sound effect button on the remote simultaneously for 10 secs and the soundbar screen will show reset mode. Switch off and switch on the soundbar.
Posted on Feb 10, 2018
2 Related Answers
Anonymous
SOURCE: LG HBS 200 connection to the computer
the default passkey is 0000. try it and see if that works.
Posted on Mar 03, 2009
Anonymous
SOURCE: lg 42ls3400 wont connect to my nb2420a sound bar?
Did you ever find an answer for this? I have the exact same problem. Seems like there is no optical out on the tv.?????
Posted on May 08, 2012
LG sound bar NB353OA want connect by BT. I try few different devices like 3 smartphones, TV and laptop any everyone can't find it. I was did reset of soundbar and still nothing. On screen say BT READY but...
http://gscs-b2c.lge.com/downloadFile?fileId=KROWM000598807.pdf
Bluetooth® profiles In order to use Bluetooth® wireless technology, devices must be able to interpret certain profiles. This unit is compatible with following profile. A2DP (Advanced Audio Distribution Profile)
Are your devices A2DP compatible? If yes, please comment below with model no. and I'll assist further.
How do you reset your soundboar
There are two methods to reset. Hard reset and factory reset. To make it a hard reset unplug the set from the AC mains wall socket and reinsert after an hour or so. To make it a factory reset you have to enter it's service mode option. If you wish to get more details visit the site linked here. Service mode entry procedure of many popular brand devices are given in detail. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
LG PLASMA TV CLICK SOUND
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
I hv LG42inLEDTV, watchng tv thru settopbox screen still & sound continued, switchd tv off & on thn sound cme wid LG no signal logo movin up dwn, same wd DVD plyr. Bt, wn connctd to USB cn see movies
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If hard reset do not help you. do a factory reset.
Need support to stand on table
Why do you need to stand on table, might I ask?
No bluetooth option on NB3520a sound bar
I live in Israel and have the same problem with my lg 3520
Very disapointed , no salutation online..
Can an lg soundbar be connected to another brand of tv, ie a hitachi? cant gt any sound to come through !!
Depends on whether your tv supports "ARC" ( Audio REturn CHannel) or has an optical out port..the sound bars are designed to work with either the "ARC" function or optical out option
2answers
Lg 42ls3400 wont connect to my nb2420a sound bar?
H2215 Blutooth Radio failed to turn on
The problem was in the HP ProtectTools security aplication. After disable the aplication and do a hard reset the bluetooth works. I had see that after the hard reset begins a process where some HP software are installed again. One of these software is the Broadcom driver of the Wifi/BT (You can see it for two seconds in the top bar). I think that the ProtectTools blocks some file upgrade (DLL, Exe, config file, etc.) that causes the problem. After solve the problem I have restored a full system backup done before disable the ProtectTools and do the hard reset, and all still works fine. I hope this can help you.
Top LG Audio Players & Recorders Experts
Marvin
Marvin
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
