20 Most Recent
LG HX906SB 5.1ch 3D Bray and DVD Home Cinema System Questions & Answers
Boot and please wait problem
I had the same issue twice (2 diffrent devices) on LG Blue-ray HX-906 - stuck on "please wait" after switching it on. It turned out to be defective mainboard - main BGA chip (the one with black radiator) has some problem with connection to mainboard. Here is how to repair it:- dismount the mainboard- take off the radiator from the main chip- put alluminium foil around the chip to avoid unnecessary heating up of other parts of PCB- heat up the chip using air hotgun to about 200 celsius for about 5 minutes. Mount everything in reverse order and enjoy
I have a “please wait” problem in my lg home theatre (model hb906sb) ??
The "please wait" problem in your LG home theatre (model HB906SB) is likely an issue with the system's firmware or software. Try unplugging the system from the power source for a few minutes, then plugging it back in and turning it on. If the issue persists, try performing a factory reset of the system. If none of these solutions work, contact LG customer support for further assistance.
LG DVD Receiver HT552TH is not switching from DVD to AUX or Band. What to do?
Here are some steps you can try to troubleshoot the issue with your LG DVD Receiver HT552TH:
- Make sure that the AUX or Band input is properly connected to the receiver.
- Try resetting the receiver to its default settings by unplugging it from the power source, waiting for a few minutes, and then plugging it back in.
- Check the input settings on the receiver and make sure that the correct input is selected for the AUX or Band.
- Try using a different remote to see if the issue is with the remote or the receiver.
- If the issue persists, it may be a hardware problem with the receiver, and you may need to contact LG customer support or take it to a professional repair service.
Wat is s- protection on my lg home theater systerm
I'm not sure what specific LG home theater system you are referring to, but "S-Protect" is a feature found on some LG home theater systems that is designed to protect the system from damage due to power fluctuations or speaker wire issues. When the system detects a potential problem, it will automatically shut down to prevent further damage.
LG ' LH-T550TB
Your question ............................. is ..................................
