Ishtiaq Haider Posted on Oct 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have xerox d95 machine. And I m need some help. My machine give error code 077-103 .
JMJr
Level 3:
Master:
  • Xerox Master 694 Answers
  • Posted on Jul 09, 2020
 JMJr
Xerox Master
Level 3:
Master:
Answers
694
Questions
0
Helped
166691
Points
2276
5 Related Answers
Anonymous
  • 30 Answers
  • Posted on Feb 19, 2007
SOURCE: TEAC MC-D95
weak or exhausted optical lens or laser assemly,needs replacement or adjustment,see a doctor.
Anonymous
  • 2072 Answers
  • Posted on Feb 21, 2008
SOURCE: I need help with xerox.
It really sounds like there is a sensor that is hanging up.
Or if its an optical sensor its dirty.
Leave the machine off for a while and inspect the fuser area for actuators in the paper path.
You may have a spring off of on of those sensor assemblys or it is hanging up on a cover.
That sounds like what you are describing since you can make one color copy.
Also, make sure your paper size settings are correct. If you have the setting different from the actual paper size in the machine, it will shut off with more or less a false jam due to the machine expecting a size paper and the paper path sensors do not see that size as the machine is running.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jun 19, 2008
SOURCE: FAX ERROR MESSAGE
It sounds like the fuser rollers are not at the proper temperature to work.
They should be inspected by a technician.
Anonymous
  • 6 Answers
  • Posted on Jun 08, 2009
SOURCE: Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Anonymous
  • Posted on Jan 11, 2010
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Xerox D95 error code 077-313.
Try disabling it.
4112 / D95 families - Fault Code 077-313 : Multi-Feed Sensing Problems. First ... You have the choice to disable the Multi Feed Sensing feature on the machine if you fail to repair the problem or if you have a hard time sourcing the sensor or the board. The NVM Setting code is: 742-268.
4112 / D95 families - Fault Code 077-313 - The Parts Drop
The Parts Drop https://www.partsdrop.com > index.php > 4112-4127-d9...
Fault Code 077-313: Oversize High Capacity Feeder Fault
Xerox https://www.support.xerox.com > en-us > article
Sep 21, 2015 - Fault Code 077-313: Oversize High Capacity Feeder Fault · Try these solutions · Did this help?
Error Code Xerox 4112 Error 077-313
Copytechnet https://www.copytechnet.com > ... > Xerox
Sep 6, 2019 - Cause: Multi Sheet Check Sensor Actuator loose due to torsion spring disconnected from the arm. Due to improper removal of paper jam at Registration Roll.
Jamming Error 077-313 and error 075 - 211
Nov 30, 2016
Xerox 4127 cp error 077-313
Sep 24, 2016
Error Code xerox 700 077-311
Jan 11, 2021
More results from www.copytechnet.com
Xerox Workcentre 6515 giving error code 61-354. 62-280 and 63-386.
Swapping out boards on guesses is expensive.
https://www.support.xerox.com/en-us/article/en/1470317
Looks like your second code should be 62-**3**80?
https://forum.support.xerox.com/t5/Hardware/Workcentre-6515-Device-Fault-062-380/td-p/214038
https://www.support.xerox.com/en-us/article/en/2056725
Xerox online help is not particularly helpful! Google is often a better solution, but in your case, you need a service call. One of those new boards may be faulty.
https://www.google.com/search?q=Xerox+Workcentre+6515+giving+error+code+63-386
8helpful
4answers
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
TEAC MC-D95
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
