SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
SOURCE: Maytag electric dryer (LDE9806ACE) Tumbler
Two issues to look at. One dryer belt idler pully arm. Second actual motor may have bearings acting up. May need to change both to eleminate problem.
SOURCE: maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
SOURCE: No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
SOURCE: I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element
Often a dryer heating element burns out, but
doesn't trip the circuit breaker or blow a fuse. The heating element is
simply a long coil of special wire. You can check it for continuity with
an ohm meter. No continuity means the element is bad and you need to
replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to
the exhaust duct inside the back cover panel. The fuse--which is about
an inch long--is usually embedded in black resin and mounted in a white
plastic housing. If the fuse has blown, you need to replace it. (You
can't re-set it.)
Wiring
A common problem is for the main wiring connection
from the house, at the dryer, to burn and break its connection. Because
the dryer can still tumble with partial power, the connection may be
only partially defective. You may need to replace both the power cord to
the dryer and the terminal block inside the dryer that the wire is
attached to.
