20 Most Recent Maytag MLG15PD Gas Commercial Dryer Questions & Answers
0answers
0answers
Error code d5 maytag
indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not beleive the door is closed and/or locked, so it shuts down the machine.Here is the service manual which will tell you how to do some testing of the door lock, but in the end you may need both a control board and a door lock assembly. The good news, they are easy to change out, the bad news, they are expensive parts so you want to be as sure as possible before you buy and install.http://www.servicematters.com/maytag...s/16026126.pdf
3/29/2012 7:15:50 PM • Maytag MLG15PD... • Answered on Mar 29, 2012
The dryer will not heat. The glow plug glows but
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
8/20/2010 7:58:27 PM • Maytag MLG15PD... • Answered on Aug 20, 2010
Sail switch open fault
the sail switch is a safety device that turns of the dryer if insufficient airflow is detected out of the dryer vent. make sure the dryer vent is clear and air flow out of dryer vent is not obstructed in anyway.
7/3/2010 5:27:22 PM • Maytag MLG15PD... • Answered on Jul 03, 2010
Maytag Atlantis MDE6200AYW dryer. The buzzer won't shut off?
THE BUZZER WON'T SHUT OFF ON MY MAYTAG ...
JustAnswer https://www.justanswer.com > Appliance Repair Jul 21, 2017 - The way it works is that power from the heater goes to the motor so that the heater can't heat unless the motor is running. 1 answer ยท Top answer: The buzzer is not actually controlled by the timer. It's controlled by the centrifugal switch ... ..
2/20/2024 5:37:54 AM • Maytag Dryers • Answered on Feb 20, 2024
Maytag Dryer Model MGD5630HW3 Buzzes when starting a cycle and wont start the drum.
bad start up capacitor for motor
2/10/2024 7:57:59 AM • Maytag Dryers • Answered on Feb 10, 2024
Maytag 5000 series steam dryer. It won't start. it keeps flashing F01. What does that mean?
Question edited for clarity. Question moved from Misc Category. F01 is a very straight forward error and it means that your dryer has detected a short in the main relay power control board mounted to the left side wall under the top panel of the dryer. Oct 19, 2018
Our Maytag 5000 series dryer is showing an F01 error code.
F01 - Error Code - Dryer
Maytag https://producthelp.maytag.com > ... > Starts with F Dec 14, 2019 - Possible Solutions. Power unit down by turning off the circuit breaker(s) for one (1) minute. Power unit up by turning on the circuit . ..
2/1/2024 4:20:32 AM • Maytag Dryers • Answered on Feb 01, 2024
How do you light a pilot light on a Maytag dryer
most likely has hot surface ignitor, does not have free standing pilot.
1/12/2024 3:58:56 PM • Maytag Dryers • Answered on Jan 12, 2024
Where is the pilot light on a Maytag dryer
what is the model number? free standing pilots have been gone for several years. Google your model number and include parts. This will give you sites that sell parts. You most likely have and hot surface ignitor.
1/12/2024 3:57:12 PM • Maytag Dryers • Answered on Jan 12, 2024
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F Then check related searches MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
12/17/2023 1:41:53 AM • Maytag Dryers • Answered on Dec 17, 2023
What dose it mean F07 Maytag dryer
The F70 indicates a communication error code between the main control on the top left and the user interface on the front. Unplug the machine and remove the top. Check the connection on the board in the white plastic housing on the top left. Next check the connections on the board on the front.
12/4/2023 9:19:04 PM • Maytag Dryers • Answered on Dec 04, 2023
Can I buy a replacement shaft for the timer for my dryer?
Contact maytag repair dept! Hope this helps should be a contact number on the back!
9/16/2023 10:22:58 PM • Maytag Dryers • Answered on Sep 16, 2023
Maytag MLG15PD Gas Commercial Dryer Logo
12 questions posted
Top Maytag Dryers Experts
Marvin
Marvin
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
error code d5 maytag
  • Dryers
