You need to remove the top. They usually pop off. Then you can see down inside the machine and take out the screws that hold the front panel on.
Posted on Aug 08, 2013
SOURCE: how to remove the front panel of a maytag epic z dryer
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Apr 17, 2012
SOURCE: how to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Posted on Apr 21, 2010
SOURCE: open front panel on maytag Sde3606ayw?
there are 2 screws near the floor below the door that will let you access the lower front area,then you can remove the door assy and finally the top cover if necessary
Posted on Apr 19, 2010
SOURCE: How to remove top and front panel on Maytag Dryer model MDE9206AYW
To access these parts you first need to first lift the top up. This is done by pressing the clips inward. These are located on the left and right side in between the top and front on the dryer. When this is done the top will left up and backwards. Next, on the upper inside there are two screws, usually 5/16" bolts, that will need to removed to take the front off. Now you'll will access to the inside of the dryer. The belt will have to be removed to to take the drum out to test the rollers.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 07, 2012
SOURCE: Have a Maytag Bravos XL MEDB9504WO that works, but
Sounds like you need new drum rollers, so you need to disassemble the front of the machine and remove drum replace all drum rollers and idler pulley also check blower for damage.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Posted on Aug 01, 2013
