Support for Sansa Clip:
http://www.sansa.com/support/sansa_clip/faqs
User manual for this device can be opened with adobe reader:
http://www.sansa.com/sites/default/files/downloads/CLIP_UM_0608_ENG.pdf
SOURCE: how to put music on
well, there are a couple main options for loading your player. one is mtp or media transfer protocol which uses a program (such as windows media player) to transfer music. the other is to use msc or mass storage class and this allows you to manually drag and drop your files. you can check which one is currently used by going into your settings menu on your clip. it's most likely on auto detect, meaning it'll determine on it's own how it will sync depending whether or not it's being through a media player or not. well hope that helps ya
SOURCE: I just got a sansa clip 1gb mp3 player & need help on everything!
The Sansa Clip is not compatible with iTunes. You will have to get your music from another music service, preferably one that gives you the songs in mp3 format instead of AAC format (although it will accept WMA's, the DRM-protection system on most WMA's will give you problems down the line, especially if you cancel the music service that you got them from - songs in mp3 format will be usable even after you've cancelled your music service subscription).
-Tha Mp3 Doctor
SOURCE: My pc is not recognizing my sansa mp3 player clip model 1GB. Do I
Here is the manipulation to be done to remedy this.
To begin, open Windows Explorer and click the Tools /Folder Options /Display. Look in the list "Hidden files and folders" and check "Show hidden files and folders."
