I installed my 2 12" dvc 2ohm woofers and i have a 1400 watt amp to get to 2 ohm i wired my woofers in series/parralell. the amp is bridged but no sound will come out of the woofers (sometimes i turn my woofers off from headunit then on and they sound for like 10 seconds then turn off again) i installed it two days ago worked great for about 10 minutes then stopped and i would appreciate any input anyone has to offer
Your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Testimonial: "thanks for your help"
