I stopped using my m505 for several months and after I charged it overnight, the screen displays the "Use stylus to tap center of target." but does not respond to the stylus. It is locked on this screen and none of the buttons, including the power button, seem to work to change the screen. Suggestions? I saw the suggestion to slide a business card between the digitizer and the screen, but am unsure what is meant by that...?
The digitizer is very thin and paired with the screen. Sometimes they can get so pressed together with time and storage that can cause it to fail. Some people believe that you can put a spacer in there to separate them and try to "unstick it". This involves taking your screen apart and it might not even fix your issue. I would look on eBay or other sources for a replacement screen and just replace the whole thing personally.
