20 Most Recent Palm m505 Handheld Questions & Answers
0answers
manual
0answers
2answers
Outlook on IBM T42
You never mentioned your drivers, they could be out of whack. Try updating them or get a Microsoft compatible driver. Check the device manager for problems.
12/18/2009 7:06:11 PM • Palm m505... • Answered on Dec 18, 2009
I stopped using my m505 for several months. How
I would charge it over night. If the batteries went completely dead sometimes it takes an extended period of time to charge them. If that doesn't work try using the free palm chat. I have enclosed that link. Scroll to the bottom of the page and you will see Palm chat. From there click on the link that says chat now.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/m-series/m500/unlocked/supportservices/page_en.html
11/19/2009 4:55:38 PM • Palm m505... • Answered on Nov 19, 2009
2answers
Instruction manual for palm pda m505
PLEASE LOG ON TO..........
http://www.palm.com/us/search/index.html?search=m505%20manual
PLESAE RATE ME..
THANK YOU
9/20/2009 6:50:41 PM • Palm m505... • Answered on Sep 20, 2009
Screen not responding following extended period of storage...
The digitizer is very thin and paired with the screen. Sometimes they can get so pressed together with time and storage that can cause it to fail. Some people believe that you can put a spacer in there to separate them and try to "unstick it". This involves taking your screen apart and it might not even fix your issue. I would look on eBay or other sources for a replacement screen and just replace the whole thing personally.
8/21/2009 3:07:52 PM • Palm m505... • Answered on Aug 21, 2009
I use my palm m505 but it cant connect to my pc.
Make sure Cradle firmly connected.
Check the connection type and enable the USB connection
Get latest HotSync software at palm.com
You may also use Infrared to connect to the PC
Good Luck
7/8/2009 9:09:12 PM • Palm m505... • Answered on Jul 08, 2009
Battery needs replacement,have removed 4 rear screws what is next
asked google picked a website found clear instructions including pictures
3/31/2009 1:31:52 PM • Palm m505... • Answered on Mar 31, 2009
Palm 505 - Windows XP Unique Sync Error
Downgrade to 4.0
2/24/2009 1:22:18 AM • Palm m505... • Answered on Feb 24, 2009
Palm m505 problem after hard reset
ouch... Try opening it up and run a business card between the digitizer and the screen. Fixes m500s and m100s.
11/2/2008 12:53:27 AM • Palm m505... • Answered on Nov 02, 2008
2answers
Palm m505 Won't Start Up
I have an M505 with the same problem. After taking off the back cover, I found a defective (short circuit) SOT23 device nearly centered just below the expansion card slot. The markings are A5RGC, but I have been unable to verify whether this may be a programmable UJT (BRY61), a transistor or a diode. Does anyone have a schematic diagram, or kno where to get one?
4/16/2008 2:05:56 PM • Palm m505... • Answered on Apr 16, 2008
Can't synch my contacts, calendar, tasks or notes to my Palm m505
In order to remove the username from your Palm m505 you need to go into memo pad, create a new document, now the ticky part, you need to right in grafitti a cursive L (hand written low case l) followed by tapping on the screen twice (will produce one period), then the number 5. To test this you can follow the same procedure but change the number 5 to number 4. You should end up with Handheld does not have a usernameand all of your data will still be retained in your Palm. Now when you go to synhronize on your computer select the new user on your computer.
9/12/2005 5:35:52 PM • Palm m505... • Answered on Sep 12, 2005
Syncing with Outlook 2003 problems
Download the Outlook Security Add-in from this site: http://www.mapilab.com/outlook/security Advanced Security for Outlook is free for commercial and non-commercial use. I have testet it with Windows XP and Outlook 2002 SP3 syncing with a Palm Zire 31 and it works fine.
9/11/2005 5:04:59 PM • Palm m505... • Answered on Sep 11, 2005
2answers
How do I switch from HotSync with Palm Desktop to HotSync with Outlook?
I have a T5 and assume it's the same, but try putting your software install disk in your new PC at work. One of the options is to change sync with Palm Desktop and Outlook.
9/11/2005 3:12:26 PM • Palm m505... • Answered on Sep 11, 2005
Palm Pilot M515 PDA getting 'Fatal exception'?
Question edited for clarity. The is help here, but don't forget this is a computer relic from 2001. https://www.google.com/search?q=palm+pilot+m515+fatal+exception ..
3/12/2023 6:45:15 PM • Palm Computers &... • Answered on Mar 12, 2023
I have forgotten my email address to assess my palm phone
You will either have to remember it or factory reset the device and start again with no data.
12/20/2021 6:59:30 PM • Palm Computers &... • Answered on Dec 20, 2021
Palm m505 Handheld Logo
25 questions posted
Popular Products
Top Palm Computers & Internet Experts
Marvin
Marvin
NOEL
NOEL
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Palm Computers & Internet
Most Popular Question
instruction manual palm pda m505
  • Computers & Internet
