Toshiba gigabeat MES60VK Digital Media Player Logo
Posted on Aug 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Softwear problem i have a toshiba portable windows mobile s series it is haveing a problem of softwear problem as i charg it it shows a yello triangle with 1 in it and tells to connect it to the computer and see the user manual to restore it but i dont have it please please help me out here
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
162
Points
Whne mine did this I shut it off by turning off the battery, ( using a paper clip for the switch on the bottom of the case), as none of the regular controls worked. When I plugged it into the charger and turned the battery on all was okay again. I think my battery is going bad, and I am looking for new one
Anonymous
Level 3:
  • Master 378 Answers
  • Posted on Aug 18, 2009
Anonymous
Master
Level 3:
Answers
378
Questions
0
Helped
114401
Points
1195
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Cannot find a webcam driver or softwear for toshiba satellite l305d-s5868
Simply go to Toshiba's download website: http://www.csd.toshiba.com
1. Then click on "Download"
2. Select Laptops > Satellite > enter l305d-s5868 in the "Model Finding Filter:"
3. Then use the "Refine Search By" to show "Camara"
You should see the driver after that.
Thanks and good luck!
3answers
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Hi, well i have a toshiba e-studio 161 equipment, and i have windows 7 ultimate installed in my pc i've found drivers but them doesn't works i don't know if that is because my system it would be nice if...
Solution :
1. Cheak ur communication cable ?
2. re-install the softwear
3. when u command print by the copier what it says ??
I think it'll be the communication problem may the the cable or the softwear contol menu, u have to read the user guide 4 this printer and learn how to connect and apply this from the copier.
Looks like i have the softwear bluetooth stack for windows. but i can't find my devices like my ph.
Hi, I'm going to give you instructions on how to find Bluetooth Devices. 1. Click on the “Start” button on the Taskbar. 2. Point, and click on “All Programs" in the [Start Search Window], type: toshiba.” 3. Scroll to find, "Toshiba Application Installer."
4. The Application and Driver Installer appear!
5. “Scroll to find the “Bluetooth application.”
6. Click on the application to "Highlight," to the right, click Install.
Follow all the instructions thereafter carefully! “Let me know how things worked out for you by giving a "Helpful Rating" I will appreciate it, thanks.”
WHEN I INSERT MEMORY CARD COMPUTER OR MOBILE NOT SHOW
these is not problem in ur mobile..its a prblm in ur computer
You can fix this issue by following some simple steps given below.
1. Click Start, click Run, type compmgmt.msc, and then click OK.
2. In the console tree, click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. Now a assign a new drive letter which is not being used by any of your drives in My Computer.
5. After assigning the new drive letter your portable drive will show up in my computer with other drives
i hope the above solution will help to fix this trouble.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Have Smart NAVI DOTN300 put new battery in .does not load up.
this is a broblem with the softwear it dose not shut the gps off and run the thin dead you can upgrade the softwear to igo 8.34
16helpful
7answers
I want anti virus for my phone nokia 5130 express music
down this kaspersky mobile security ;i think it's best for mobile here is the link :http://rapidshare.com/files/310081687/Kaspersky_Mobile_Security.rar
read the discription
Description:
The best antivirus for your mobile.Just install update and kill everything that might try to come in your mobile.
You can use one of the standard methods to install the program on your phone:
1. Transfer the distribution package of the program from the PC to your smartphone via a BlueTooth or infrared connection. Launch the installation of Kaspersky Mobile Security from your device and then follow the installation instructions on the screen.
2. For smartphones based on SymbianOS: If you have the Nokia PC Suite installed on your PC, right-click the distribution package file, select Install with Nokia Application Installer from the menu, and then follow the installation instructions on the screen.
3. For smartphones and communicators based on Windows Mobile: Connect your device to your PC via Microsoft ActiveSync and copy the distribution package of the program to a folder on your device. Use the device’s built-in file manager to launch the installation of Kaspersky Mobile Security.
4. Using a memory card. Copy the distribution package of the program to a memory card. Insert the memory card into your smartphone and launch the installation of Kaspersky Anti-Virus Mobile using the built-in file manager.
TESTED ON NOKIA N-SERIES
TESTED ON WINDOWS MOBILES (O2/HTC/SAMSUNG)
OTHER NOKIA SUPPORTING MODELS
NOKIA
Nokia 3250
Symbian 9.x Series 60 3rd
Nokia 5320 XpressMusic
Nokia 5500
Nokia 5700 XpressMusic
Nokia 6110 Navigator
Nokia 6120 Classic
Nokia 6121 classic
Nokia 6124 classic
Nokia 6210 Navigator
Nokia 6220 classic
Nokia 6290
Nokia 6650
Nokia E50
Nokia E51
Nokia E60
Nokia E61
Nokia E61i
Nokia E62
Nokia E65
Nokia E66
Nokia E70
Nokia E71
Nokia E90
Nokia N71
Nokia N73
Nokia N75
Nokia N76
Nokia N77
Nokia N78
Nokia N80
Nokia N81
Nokia N81 8GB
Nokia N82
Nokia N91
Nokia N91 8GB
Nokia N92
Nokia N93
Nokia N93i
Nokia N95
Nokia N95 8GB
Nokia N95-3 NAM
Nokia N96
O2 MODELS
O2 XDA Atom
Windows Mobile 5.0, 6.0, 6.1
O2 XDA Atom Exec
O2 XDA Atom Life
O2 XDA Flame
O2 XDA Stealth
MOTOROLA MODELS
Motorola ALL COLOR SCREEN MODELS (WITH COM COMPATIBILITY)
Motorola Q
Motorola Q GSM
Motorola Q q9
HTC
HTC
39
HTC 3450 Touch
HTC Breeze
HTC Galaxy
HTC Hermes
HTC MTeoR
HTC Omni
HTC P3300 Artemis
HTC P3350 Love
HTC P3400 Gene
HTC P3452 Touch
HTC P3470
HTC P3600 Trinity
HTC P3600i
HTC P3650 Touch Cruise
HTC P4350 Herald
HTC P4550 Kaiser
HTC P5500 Touch Dual
HTC P6300 Panda
HTC P6500 Sirius
HTC P6550
HTC Prophet
HTC S310 Oxigen
HTC S320 Monet
HTC S420 Erato
HTC S620 Excalibur
HTC S630 Cavalier
HTC S710 Vox
HTC S730 Wings
HTC Star Trek
HTC Touch Diamond
HTC Touch Dual
HTC Touch Pro
HTC TyTN
HTC TyTN II
HTC Universal
HTC Wizard
HTC X7500 Advantage
HTC X7510 Advantage
HTC X9500
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
