At first in diagnostics it didn't fill with water, but I fixed that. Now it runs through the tests fine.
SOURCE: WASHING MACHINE FILLS WITH WATER AT START THEN STOPS SHOWING ERROR 5
the carbon brush may be worn out and need replacement(these are a pair of componet that makes contact to the motor. Francis
SOURCE: F20 Error code
I'm getting the same F20 error code. I bought this machine used and luckily it still has a warranty. Right now we only have the cold water hooked up, but the clothes don't feel very wet and the softner is still in the softner holder.
What do I need to do to correct it.
SOURCE: Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
SOURCE: Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
