20 Most Recent Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor Questions & Answers
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Rheem Paloma... | Answered on Oct 29, 2019
Please contact your city permit office for construction requirements, they vary from city to city.
Rheem Paloma... | Answered on Jul 28, 2017
Ask the local council what the incoming water pressure is you may be able to get a water reg on the incoming line to boost pressure .
Rheem Paloma... | Answered on Jun 11, 2017
quite possibly the element has shorted . call a local plumber.
Rheem Paloma... | Answered on Dec 11, 2016
try to start unit several times to purge air from line .
Rheem Paloma... | Answered on May 21, 2015
Close entrance valve and open valve indoor' NO Smoking or any flaming
object!!!!!
Rheem Paloma... | Answered on Feb 24, 2015
Sometimes this can be done by turning the ignition key a few times, not all the way to start, just off and to the on position before engaging a start, you will here a noise for a second that's the fuel pump sending fuel to start car, so after a few clicks it builds up the fuel pressure, air is bled out naturally. ... hope this helps ?
Contact Paloma/Rheem customer (800-432-8373) support and tell them what you have; they'll send you the documentation - by regular/email.
Happy Holidays;]
JZ...
Rheem Paloma... | Answered on Jan 12, 2015
Contact your Gas company...
Rheem Paloma... | Answered on Jan 09, 2015
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Rheem Paloma... | Answered on Dec 02, 2014
Low water pressure
Clean water filter
Change water filter cartidge
Check water flow to unit
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/Crossover.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Rheem Paloma... | Answered on Sep 03, 2014
Often the conversion is done with dip switches.
Contact Rheem/ Paloma
Gene
Rheem Paloma... | Answered on Aug 17, 2014
Rheem Paloma PTG-74PVN /  RTG-74PVN Natural Gas Indoor Logo
219 questions posted
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
View Most Popular
Rheem Water Heaters
  • Rheem Water Heaters
Most Popular Question
c7 12 error code
  • Water Heaters
